Power Question - Mustang Evolution
Old 01-15-2006, 10:45 PM   #1
Power Question
Ok, so after reading the symptoms of an exhaust leak I have pretty well determined that I have an exhaust leak. The car has a "putt-putt" noise to it and it drives me insane. Will an exhaust leak cause a loss in power? I haven't noticed a dramatic difference, but if it causes power loss than Im going to be pretty adamant about fixing that little problem. BTW, I have a 00 V6 with true dual...40s series on it. And I, personally, like the sound of my exhaust...minus the leak....Thanks!
00StangV6 is offline   Reply With Quote
Old 01-15-2006, 10:49 PM   #2
Re: Power Question
a leak can cause power loss, depending on how bad it is it may not be super noticable~ if its bad though you will hear it with out issue. It shouldnt be a problem to fix it once the source is found. Pop the hood and try to track it down.
Old 01-15-2006, 11:00 PM   #3
Re: Power Question
Thanks for the help. BTW, the new car is nice. I always loved the black stang, and if you upgrade and treat the new one like you did your old one I can't wait to see the numbers it will produce.
Old 01-16-2006, 04:10 PM   #4
Re: Power Question
Check the flange on your passenger exhaust manifold, v6's are bad about separating right there.
Old 01-19-2006, 06:34 AM   #5
Re: Power Question
Yeah, I second what LOWFLYN says about the passenger side exhaust flange. Mine did (2000 V6) at about 75,000 miles, and because I was super busy at that exact time with my race car, I took it to a dealer. Like $500 later, they replaced the right bank exhaust header, and now all is well. BTW: you DO want to get after that, if that is in fact the problem, because you now have carbon mono underhood, and able to get sucked right into the pass compartment!
TheDad
TheDad is offline   Reply With Quote
Old 01-19-2006, 05:15 PM   #6
Re: Power Question
Haha...thedad, nice name. But yeh, I ended up blowing mine off and had to replace it. Ford likes to ask 180 a piece for them and just happened to have 3 in stock in the storage room, go figure.
power steering question ehlersjake Classic Mustangs 0 07-24-2008 09:56 PM
Question for all you power gurus 05bluestang 2005-2010 Mustang GT 7 11-07-2007 08:26 AM
Power question coolstang Pre-2005 V6 Mustang 10 12-30-2004 09:53 PM
Power adder question ShwoffGT 1996-2004 Mustang GT 4 11-01-2004 03:45 PM
airbag power question WhiteStang99 Pre-2005 V6 Mustang 10 06-12-2004 12:35 AM
11:19 AM
