98' V6, 3.8 - Engine Wiring HELP!! - Mustang Evolution
Old 01-16-2006, 12:58 PM   #1
Angry 98' V6, 3.8 - Engine Wiring HELP!!
Recently purchased a 98 Vert v6 for my g/f. This was a fixer upper so it was a bit cheap. The car originally didnt crank took it to my mechanic turned out it was the fuel pump that was bad. Replaced it and 48hrs later Car wont start AGAIN! I think it has something to do with the Wiring in it.
1.When i honk the horn it stays stuck and keeps honking until i unhook the battery.
2.The trunk release in the glove box doesnt work. BUT sometimes when i hit the car unlock button for the driver door (if the ignition is open) IT UNLOCKS THE TRUNK.
3. The lights on the Sun Visors dont work.
4. There are some plugs by the cold air intake that arent plug BUt i have NO IDEA where the hek they go to??
I looked up the fuse box diagram and it doesnt even look like the fuse box thats in the car. Im thinking they swapped it with one that doesnt belong to this car. Im comparing this to this exterior fuse box diagram http://www.mustangmods.com/data/1459...iorfusebox.jpg
I have attached some pictures of the fuse box and the connectors that i have no idea where they go??
Both connectors are located on the RH Passenger Fender.
Any info would help with this PHSYCO CAR!.
Thanks!
Alex
ID:	11941   Click image for larger version
alexx_302 is offline   Reply With Quote
Old 01-16-2006, 01:31 PM   #2
Re: 98' V6, 3.8 - Engine Wiring HELP!!
This is the fuse box from my 96 V6. I do not know if they changed it for 98 though, 98 somethings were changed. According to that diagram of the fuse box it looks like mine is the correct one for 94-98 V6 Mustangs. Also to note that the ground wire that I see in your picture of your fuse box does not look good either. Can you get a better picture of where that goes to?
As far as the other two connections can you post pictures farther away from the connectors so that I can better see where exactly these are located. I can not find where they are exactly on my car.
It does sound like an electrical problem with your lights however and I am 100% those cables need to be plugged in somewhere.
Old 01-16-2006, 03:56 PM   #3
I have these pictures but i can take some tonight when i get home and post them up here. The connections that are not connected are attached to the wiring harness that comes in from the passenger fender which includes the mass air meter etc.
Name:	Ericas Mustang (8).JPG
Old 01-17-2006, 05:01 PM   #4
Kiljosh's Avatar
I'm pretty sure that the Left connector in the second pic is what plugs into your intake to measure air intake temp. I think it's called the IAT sensor? I dunno i Cant go and see Im not at home.
Old 01-18-2006, 01:49 PM   #5
Ok guys i switched the whole wiring harness. Now everything works just fine lights signal. Trunk release the whole shabang! BUT!!!!! car still wont start. NOW as soon as i plug the battery up the THEFT light starts blinking like crazy also the abs light is on at the same time. Only both those lights come on! and i get no start or nothing actually when i put the key in there and turn it. anyone know any solution to this?? Im hearing this has to do with PATS? I also just found out that the engine was swapped about a year ago.
Old 01-18-2006, 01:53 PM   #6
This sounds very similiar to this guys problem http://www.mustangevolution.com/foru...6-mustang.html
Old 01-18-2006, 06:36 PM   #7
redfire2003's Avatar
the reason why the car will not start is the Passive Anti Theft device. It has a micro chip in the key that it doesnt recognize. You will have to go to the dealership and have the key reprogrammed. You will have to have 2 keys to get this done. It takes about 5 minutes to get to the security access. Once there it takes 10 minutes to gain security access. After that is done they will erase all key codes and then program the 2 keys with new ones. Whole thing takes about 20 minutes or so.
redfire2003 is offline   Reply With Quote
Old 01-19-2006, 12:21 AM   #8
Just curious before i go to the dealer. When PATS are enabled does the car try to turn on? does the engine atleast turn because thats what the case seems. This car doesnt even make a sound its kinda like trying to turn on the car when you have the shifter on the "Drive" position. *Just thought i would throw that outthere!
Thank you all for your help!! Seriously.
Old 01-19-2006, 12:35 AM   #9
Your car won't turn over or attempt to without the right PATs key.
Old 01-19-2006, 06:51 AM   #10
Where did you get the car from? 2:
Good luck and all best,
Joe
1998 Laser Red V6 manual . . . Kenny Brown suspension, Eibach pro-kit springs, BBK CAI, JBA shorty headers, Magnaflow duals, GT fogs, Aluminum driveshaft, 3.27 gears, Tri-Ax shifter handle, misc UPR and MGW billet accessories, SS inserts, Redline Goods shift boot
1998Stang is offline   Reply With Quote
Old 01-19-2006, 08:58 AM   #11
The car WILL turn over it just will not start. We had a customer come in to our ford dealership and his mustang would turn over but would not start, his problem happened to be the chip fell out of his key. Cut new key and reprogramed and it started fine. Brad
Old 01-23-2006, 03:10 PM   #12
Question Re: 98' V6, 3.8 - Engine Wiring HELP!!
Had a locksmith over and he said my pcm is the problem he took it out of my fenderwell and it looks like it was hit by a garbage truck at 90mph. He wasnt able to communicate with the pcm in order to get into the pats and the pcm starting making this loud weird noise that he had never heard. Pretty much its missing the cover and its all dented up (im assuming car was in a accident or something) Anyway i went to the local wrecking yard to replace it but they said they need a Part# for my model. That they dont want to give me the wrong one. Part# suppose to be on the cover of the pcm but obviously w/ the cover missing no luck there. It is a 98 mustang 3.8 Anyone know where i could get this model / part Number??? THANKS GUYS!!!
Old 01-23-2006, 03:47 PM   #13
I believe there are a few options, or part numbers. Need to get a chip tunner in here to make sure~
Old 01-23-2006, 08:00 PM   #14
I will check when I get to work in the morning and give you a part number. Will you give me the vin number to further cut down the choices. Brad. Oh yeah if it was the right fenderwell if I am not mistaking the part you are seeing is the fan control/PCM relay. Take a pic and post it if you can please.
Old 01-25-2006, 12:29 PM   #15
Okay the the Vin# is 1FAFP4448WF200209. I guess they must have more than one model PCM because everyone is asking me for a part# and some other number that should be on the outside of the box?
Old 01-25-2006, 01:51 PM   #16
OK the ford part number is F8ZZ-12A650-HC. The number that they would look for on the pcm would be the engineering number which is F8ZF-12A650-HC. Any more questions just ask. Brad
Old 01-26-2006, 11:05 AM   #17
Check this link, I believe it has better wiring pictures.
Click on 2000 Mustang Workshop Data and click on fuse locations or wiring harness.
If its the same I have the wiring harness with the battery junction box that go around the radiator. For a 2000 Mustang 3.8L
e-mail me rar3206@cox.net
http://www.miracerros.com/mustang/index.htm
Thanks!
Alex
rar1955 is offline   Reply With Quote
Old 01-27-2006, 10:31 AM   #18
Red face Re: 98' V6, 3.8 - Engine Wiring HELP!!
So Brad before i could get ahold of a part# my brother in law brought this over to my house. Will this NOT work for my car? This is for a 98 as well. Do you know if the correct one will have a big "S" like this one on the pic?
Thanks for all your help bro!!
Rgds,
Alex
ID:	12036   Click image for larger version
Name:	98 PCM 2.JPG
Old 01-27-2006, 11:00 AM   #19
That is the pcm/fan relay (multifunction relay) and yes that is the exact one needed for your car will work fine. Brad
Old 01-27-2006, 04:18 PM   #20
So even though the part# is diffrent it will still work for my car? Is there any diffrence between stick and auto?
Old 01-27-2006, 05:32 PM   #21
There was only 1 choice for a 1998 with a 3.8 and that happens to be the correct one.Does not matter if it is auto or stick. Brad
03' motor and tranny swap with 98' GT PLEASE HELP!!! BAttitude7689 1996-2004 Mustang GT 10 01-20-2010 06:33 PM
2000 Mustang V6 Wiring Door panel wiring problem wyatt-00' Pre-2005 V6 Mustang 3 11-30-2009 12:43 AM
98' V6, 3.8 AUTO PCM PART#??? alexx_302 Pre-2005 V6 Mustang 0 01-23-2006 03:27 PM
FS: Rear 96-98' Tail light Bezels KrazyPony Mustang Parts for Sale and Wanted 3 12-30-2004 04:33 PM
Brakes for the 98' KrazyPony Mustang Parts for Sale and Wanted 3 06-15-2004 07:45 AM
02:32 PM
