I think i need a new clutch - Mustang Evolution
Go Back   Mustang Evolution > 4 Cylinder | V6 | Classic Mustangs > Pre-2005 V6 Mustang
Closed Thread
Old 01-20-2010, 11:39 AM   #1
SaturnMan8227's Avatar
SaturnMan8227 is unknown around these parts
Send a message via AIM to SaturnMan8227
hey guys i think i need a new clucth. About 90% of the time when i step on the clutch pedal i notice really loud squeel. I also noticed that the feel of the pedal has gotten super stiff. A freind of mine said it was either my throw out bearing or pressure plate maybe both. Still need to take it in and get her checked.
if it is the clutch; is there any difference between a 99-04 3.8L or 3.9L clutch? I dont think there is. Most of the stuff i have said it was for a 3.8L. I just want to double check before i order a kit. all isee are the kits for a 3.8L.
as always thanks
SaturnMan8227 is offline
Old 01-20-2010, 11:47 AM   #2
upton7's Avatar
upton7 is unknown around these parts
Re: I think i need a new clutch
no difference in 3.9 i think they should stop saying "will fit 3.8" and start just saying whatever year range then just put v6
upton7 is offline
Old 01-20-2010, 02:32 PM   #3
Terminator Owner
SpectorV is just getting started.
if you go into it replace it all as its cheaper to do it then dont just do one or two parts. I would just go back with the OEM setup.
dont forget the pivot ball stud, throwout bearing, and inspect the clutch fork as well as the sleeve the throwout slides on for scratches, replace as needed.
Check the input shaft for correct tolerance (wiggle room) etc etc
SpectorV is offline
Old 01-20-2010, 11:36 PM   #4
Well weither it was one of the problems i listed above the car is dead. luckly it died in front of my parents house so it is safe. as of now my mustang is down for the count. the clutch pedal is stuck to the floor and i can not get it into any gear when started. If i out into gear and try to start the car it just jerks forwards. god to today has been a bad day
Old 01-20-2010, 11:47 PM   #5
lowflyn is unknown around these parts
Then it sounds like a clutch issue....
lowflyn is offline
Old 01-21-2010, 01:03 AM   #6
yeah. i figure its the entire clutch assembly. no big deal. just have drive my mom's saturn for a while. god that thing has no balls. thinking maybe a clutchmaster clutch kit. if i plan on going boost this summer might as well beef up the clutch. then again a oem spec clutch kit is cheaper. i will let you guys now what i go with.
Old 01-23-2010, 12:42 PM   #7
big show 98's Avatar
big show 98 is unknown around these parts
+1 oem
1998 coupe auto 3.27
2.25 h-pipe 2 cats
2.25 gt cat back
Mac UDP
K&N drop in
big show 98 is offline
Old 01-27-2010, 01:54 PM   #8
Ok so I was looking to get one of those adjustable cable kits from american muscle. But not sure if it would work for my V6. Any reason why they would only be labled for a GT??
Old 01-29-2010, 03:35 PM   #9
Ok, so the car is in the shop. It's needs a new clutch kit, Throw out/Release bearing, clutch fork and pivot ball stud. $600 parts and labor should be back on the road by tomorrow.
Old 01-29-2010, 09:03 PM   #10
Terminator Owner
sounds good keep us posted
SpectorV is offline
Old 01-30-2010, 08:43 AM   #11
Got the car back last night. wow talk about an improvement. feels completely different. the clutch pedal is super soft. it like a new car.
Old 01-31-2010, 09:25 AM   #12
Terminator Owner
sounds good!
SpectorV is offline
Closed Thread
clutch help guerrerosal Pre-2005 V6 Mustang 4 03-22-2009 11:19 AM
need a clutch and... DarkShadows 1996-2004 Mustang GT 12 01-02-2009 11:54 AM
New clutch electricstang Pre-2005 V6 Mustang 2 05-22-2006 03:04 PM
best clutch ? jedwards242000 Pre-2005 V6 Mustang 5 04-09-2005 03:21 PM
Clutch Murph00 Pre-2005 V6 Mustang 2 06-30-2004 04:00 PM
08:24 AM
