JBA Spark plug wires, 8mm or 9mm? - Mustang Evolution
Old 01-22-2006, 02:02 PM   #1
ricklmesa's Avatar
Im thinking of getting some JBA spark plug wires but there are two choices. 8 mm & 9 mm. Doe's anyone know the difference between the two performance wise? Would it be ok to go with the 9 mm?
Procharger P1SC,3 Corecooler,42lb inj.
301whp & 300wtq @ 10psi dynojet SAE 106 degrees
ricklmesa is offline   Reply With Quote
Old 01-22-2006, 08:44 PM   #2
Re: JBA Spark plug wires, 8mm or 9mm?
9mm is fine for N/A
Old 01-22-2006, 09:08 PM   #3
neither will do anything other than add a bit of looks to the car, wait until they are high in milage then replace them as regular upkeep.
Old 01-24-2006, 05:11 PM   #4
ricklmesa's Avatar
yea thats what everyone's tellin me. Thanks for the input, I think ill just hold off till I can do the whole ignition. MSD or something in the future
Old 01-24-2006, 05:39 PM   #5
Whole ignition will do you no good unless you really start into the engine.
Old 01-24-2006, 06:32 PM   #6
put the money into mods that will help, but nearly all mods barly help
Old 01-24-2006, 10:40 PM   #7
Whole ignition will give you 0 gains
11:30 PM
