MAF gone bad - Mustang Evolution
Old 01-23-2006, 12:32 AM   #1
powerhungry966's Avatar
Send a message via AIM to powerhungry966
Question MAF gone bad
i recently got my car smogged and it failed, they said that it had something to do with my MAF and two other parts.. so i thought ****.. ima have to replace that **** and its going to cost me! i was thinking of getting a 80mm or a lighting MAF, and my question is will it pass with a lightning MAF and is it a simple plug and play type action or would i have to update various parts before i can run an 80mm MAF? help please thanks
1989 coupe 5.0 yeessur.
"Shake n bake"
powerhungry966 is offline   Reply With Quote
Old 01-23-2006, 06:18 AM   #2
slvr2000stang's Avatar
Re: MAF gone bad
Do you have the details on why you failed and what they said?
Also some details on your car would be helpful.
Custom Delk motor now DOA
2003 SVT Lightning #1059 of 4270
2000 Vert 4R70W
Only buy from vendors that test and stand behind their products
slvr2000stang is offline   Reply With Quote
Old 01-23-2006, 08:20 AM   #3
Re: MAF gone bad
dont upgrade the maf, its useless unless you have a good bit of power. Just grab one for cheap somewhere. Make sure that is the problem, it may just need cleaning (very easy to do with a tamper proof torx bit)
Old 01-23-2006, 06:06 PM   #4
I_luv_HP&trq's Avatar
Send a message via AIM to I_luv_HP&trq Send a message via MSN to I_luv_HP&trq
Re: MAF gone bad
I'd figure out what those other two parts are first. They should have given you a print off of what passed and failed. Scan it in so we can take a look at it. I have a 99 maf I might be able to sell you soon but I don't know if we both have the same pin connectors.
99 Cobra: flowmasters, 18x9.5 cobra R's, soon to be tuned and geared. daily driver
99 V6:in avatar, Mac Cai, true duals/flowmaster 40's ,UDP, custom tuned, bullitt suspension 18" wheels...taken by mother nature
I_luv_HP&trq is offline   Reply With Quote
Old 01-23-2006, 06:18 PM   #5
Re: MAF gone bad
is it larger then my cock hole of a maf? update.. it passed now.. just need to replace two parts.. fairly small, $160.. that son of a B***h told me i have to replace it(maf) when really it didnt need to be.. when i told to to try cleaning it it passed.. son of a ***** almost cost me 2hundred dollars from ford! caution on those repair shops all..
"Shake n bake"
Old 01-24-2006, 12:07 PM   #6
Re: MAF gone bad
what parts do you have to replace? The more I learn the more I realize how I've been screwed over by shops and smog people... You may be able to get whatever parts you need for less.
MAF bsmith782 1996-2004 Mustang GT 12 01-30-2007 04:07 PM
When things go bad... they really go bad for some people Brent The Bar 8 12-13-2006 09:31 PM
Hillarys such a bad bad girl.... Brent The Bar 24 03-31-2005 04:41 PM
Maf ? FloMasta24 Pre-2005 V6 Mustang 8 02-24-2005 06:07 PM
is this what your MAF looks like.... project232 Pre-2005 V6 Mustang 13 02-23-2005 03:47 PM
05:20 PM
