Need Help: Codes P0135 and P0155 - Mustang Evolution
Old 01-24-2010, 03:19 PM   #1
Exclamation Need Help: Codes P0135 and P0155
I have a 96 Mustang V6...
P0135 is for bank 1, sensor 1 and P0155 is for bank 2, sensor 1. Anyways, my CEL came on and these are the two trouble codes I have. I felt it was unlikely for both sensors to go bad at once, so I got under the car yesterday and checked them out. The connectors looked fine. These are 4 wire sensors, 2 white, 1 gray, and 1 black. I got on the internet and found where the two WHITE wires are for the heater resistor in the sensors. Using a multimeter i checked the resistance between the two wires and got 6.5 ohms for both sensors. Does this seem in spec? If so, then I doubt my sensors are bad.
I then checked to see if I was getting voltage to the sensors. To do this I turned the key to ON, engine OFF, and put my positive prong (from multimeter) into the female end where the BLACK prong of the sensor pig tail would go, and put my negative prong (from multimeter) into the female end where one of the WHITE prong of the sensor pig tail would go. I couldn't get any voltage to read on my meter. Out of curiosity, I checked the voltage to one of the back (after the cat) sensors, using the same method, I got 5.7 Volts.
So, now i'm thinking I'm not getting voltage to both of my front sensors. Could someone please help me out as to where I should go next? At first I thought I might have bad sensors, but now I'm starting to think I have a problem elsewhere...
96Mustang0250 is offline   Reply With Quote
Old 01-24-2010, 04:22 PM   #2
Zebs5408's Avatar
Re: Need Help: Codes P0135 and P0155
pick u up a haynes manual bro and it will really help u out, this sounds like something sonicpony should be able to asst u with he'll be on sometime tonite!
04' mustang 3.9 40th Anniversary Edition- (V2 Vortech Supercharger, 38# injectors, 3.73 gears w/ T-lok, Predator Diablo, Mac cold air intake, Port & polished upper AND lower intake manifold, Mac Long Tube Headers, Mac o/r H pipe, flowmasters, 2.5 flowmaster tips)
03' Mustang GT (20" Cobra R's, 40 series Flowmasters)
Zebs5408 is offline   Reply With Quote
Old 01-24-2010, 08:27 PM   #3
Could It be a fuse? Does anyone know what fuse # I should look at? I didn't get much help from owners manual.
Old 01-25-2010, 09:15 AM   #4
96mustang21's Avatar
when you checked the voltage was the exhaust at normal operating temp the haynes manual says the 02 sensors produce no voltage when it is below normal operating temp of about 600 degrees f. allow the engine to reach normal operating temp and check that the 02 sensor is producing a varying signal voltage between 0.1 and 0.9 volts. if you get no signal they are probably bad
96 v6 bottom end, sc heads, eaton m90, sc tb, bbk headers,custom tru dual 2.75 exhaust H-pipe flowmaster 40s, sc 8 rib belts,egr delete,5 speed, etc etc.
96mustang21 is offline   Reply With Quote
Old 01-25-2010, 10:17 AM   #5
i'm not getting voltage to the sensor. I took the sensor off and tried the "over a propane torch test" but I didn't see any voltage being produced, or I wasn't doing it right? Could someone tell me how to do this bench test correctly with 4 wire sensors?
Old 01-25-2010, 10:33 AM   #6
this might help
TTORA - Oxygen Sensor Test - Faq
Old 01-25-2010, 05:29 PM   #7
Just checked again tonight. I'm not getting voltage to the heated oxygen sensors (before the converters). I checked the sensors after the converters and I'm getting 11.4V. I checked ALL of my fuses and didn't see any bad. Where do I go from here?
Old 01-27-2010, 04:11 PM   #8
After I did the voltage checks Monday night, I disconnected the neg. battery cable to reset the computer. The next day I didn't get any CEL on the way to work. On the way back home, my CEL came on about 5 min. into the drive. So tonight I decided to go to the parts store to have them check my codes to see if anything new has popped up or just the same ones. Well...I have 2 codes; P0155 and P1151... Somehow the P0135 did not show up and I did nothing the other night to that sensor....
DTC Codes? oldtexasdog 2005-2010 Mustang GT 2 07-07-2010 08:43 AM
2 Codes Need Help tigerfan2771 Pre-2005 V6 Mustang 12 04-05-2010 09:42 PM
Codes: 94 3.8L winterwolf Pre-2005 V6 Mustang 1 01-17-2010 09:23 PM
How to fix this codes? 6opka Pre-2005 V6 Mustang 11 03-24-2009 09:46 PM
codes plungerlift01 1996-2004 Mustang GT 2 09-09-2008 10:03 PM
04:22 AM
