Re-useable gaskets? - Mustang Evolution
Old 01-26-2006, 01:28 PM   #1
I_luv_HP&trq's Avatar
Send a message via AIM to I_luv_HP&trq Send a message via MSN to I_luv_HP&trq
Re-useable gaskets?
In the near future I'm wanting to replace my head gaskets and the upper/lower intake gaskets.
Can I reuse the TB gasket? I know there's a couple other small gaskets I need to account for but I didn't know which ones or if any can be used again.
99 Cobra: flowmasters, 18x9.5 cobra R's, soon to be tuned and geared. daily driver
99 V6:in avatar, Mac Cai, true duals/flowmaster 40's ,UDP, custom tuned, bullitt suspension 18" wheels...taken by mother nature
I_luv_HP&trq is offline   Reply With Quote
Old 01-26-2006, 01:51 PM   #2
Re: Re-useable gaskets?
i would just replace them, no need in cutting corners and having to just redo parts of it again.
Old 01-26-2006, 02:12 PM   #3
very true but i don't want to replace something that's not broken. The reason i'm replacing the HG's is just to be on the safe side so i don't blow them. guess i'll try to find a good package deal on gaskets then.
Old 01-26-2006, 03:07 PM   #4
Kiljosh's Avatar
RPM has a top end swap gasket kit for a good price. I think its in the 130-150 range, but you get alot. Alll Fel-Pro too. While your at it cam your car lol.
Old 01-26-2006, 03:15 PM   #5
DarkShadow's Avatar
Send a message via AIM to DarkShadow
Don't reuse them. You can go to a parts house like Advance and get the gaskets from Felpro for less than $100 I think.
DarkShadow is offline   Reply With Quote
Old 01-26-2006, 03:46 PM   #6
I would not reuse the tb gasket
Old 01-26-2006, 04:13 PM   #7
and Felpro will be adequate for forced induc?
I know some people get gaskets and spray copper on them but I don't know if all those little tricks work or not.
Old 01-26-2006, 04:24 PM   #8
Ok so i checked RPM and his topend swap goes for $190. some of the stuff included I won't need so i'll try and find them seperately elsewhere i guess.
But one other question...Isn't there a gasket material you can buy by the sheet and make your own cut outs? I was thinking maybe for TB and other little areas I could go a less expensive route and get some quality ones for the heads and intakes.
Old 01-26-2006, 05:48 PM   #9
slvr2000stang's Avatar
Yes they do.
Custom Delk motor now DOA
2003 SVT Lightning #1059 of 4270
2000 Vert 4R70W
Only buy from vendors that test and stand behind their products
slvr2000stang is offline   Reply With Quote
Old 01-26-2006, 09:55 PM   #10
DarkShadow's Avatar
Originally Posted by slvr2000stang
Yes they do.
I checked at work tonight and a head gasket set is about $170 bucks and manifold set is $30 if I remember correctly, but these are Alabama prices...
I had to pass a seminar on selling Felpro gaskets and (I do realize it was the company that made the seminar but) I found out that they are really top of the line gaskets. For forced induction, unless you have a pre-99, you won't have problems with gaskets, especially not Felpro.
HOWEVER!!! Felpro does sell some cheapy gaskets for the tight wads that buy copper plugs and $15 spark plug wires and $15 dollar brake pads. Don't get those.
Old 01-26-2006, 10:19 PM   #11
thanks for checking. I fall into the category of being a tight wad but latey buying stuff cheap hasn't paid off for me so i guess i'll have to dig deeper into my wallet. i'm too damn stubborn to spend money that's not for a necessity like food and gas.
Old 01-27-2006, 05:07 PM   #12
Region: Iowa
Send a message via AIM to Horse Send a message via Yahoo to Horse
Just don't take off the TB, then you don't need a new gasket. A head gasket set generally doesn't come with a TB gasket. Also it may not include an EGR gasket.
4.2L , CAI, BBK 65MM throttle body, 30lb injectors, SSM ported intakes, FLEX 1/2" spacer, RPM big valve heads, Comp roller rockers and cam, ASP-underdrive pulley, GT rear swaybar, & Quad Shocks, Full MM Coilover conversion, 17" Grey Torque Thrust wheels, FMS Aluminum driveshaft 8.8 rear w/ 3.73 gears, Tri-Ax Shorthrow shifter & SPEC stage II clutch w/ aluminum flywheel
Horse is offline   Reply With Quote
Old 01-27-2006, 07:19 PM   #13
Danger Dude's Avatar
Actually every T/B I have taken off the gasket stayed in great shape and I reused it. But I agree with Horse, Just dont take it off!!!!
Old 02-03-2006, 11:36 PM   #14
03YellowPony's Avatar
NEVER and I do mean NEVER reuse a gasket. I've been in the biz for 30 years. And I can tell you, if you do, you're asking for a leak.
http://i32.photobucket.com/albums/d4...llowsig7cu.png
Additional mods: MM subframe connectors, NGK IrridiumX plugs, high energy wires.
03YellowPony is offline   Reply With Quote
Old 02-06-2006, 08:15 PM   #15
Kiljosh's Avatar
Yea? What about valve cover gaskets meant to be reused. And dont some oil/tranny pans have reusable gaskets on them. Not all gaskets are reusable, but some are. My throttlebody has been on and off atleast 5 times and it is still leak free. The gasket for the upperintake to lower intake on a singleport is able to be reused as long as it is properly prepped. I have reused mine twice and no leaks yet. Spray some copper sprayagasket on it and it seal as well as a new one.
Other gaskets that are subjected to extreme temperature changes or that collapse when you torque down are no reusable. i.e. header gaskets, heads, timing cover, egr among others.
And I also agree with Corey, Just dont take the throttlebody off. Just take the upper off. Less work.
Old 02-07-2006, 11:44 AM   #16
DarkShadow's Avatar
They have to be specified as reusable, otherwise, you don't reuse them.
04 v6 Mustang GASKETS Zebs5408 Pre-2005 V6 Mustang 3 01-23-2010 12:05 PM
Where can I buy new gaskets? StgRsh Pre-2005 V6 Mustang 8 11-02-2009 09:25 AM
FPP-1006.. useable on both sides? MonteCitan 1979-1995 Mustang GT 3 01-19-2006 03:59 PM
gaskets 19ClearCobra96 1996-2004 Mustang GT 2 07-13-2005 06:51 PM
What gaskets will I need? Zim Pre-2005 V6 Mustang 10 05-31-2004 10:12 PM
11:31 AM
