4.0l Dual cam - Mustang Evolution
Old 01-27-2006, 08:33 PM   #1
05mustangmike's Avatar
Send a message via AIM to 05mustangmike
Question 4.0l Dual cam
2: Ive heard rumors of the dual cam cosworth being used to make a dohc 4.0, I gotta know if this works.2:
05mustangmike is offline   Reply With Quote
Old 01-29-2006, 07:13 PM   #2
ricklmesa's Avatar
Re: 4.0l Dual cam
Not sure but if you check in with these forums your sure to get an answer.
This forum is not that big yet for the 05 06's
www.bradbarnett.net
www.mustangforums.com
Procharger P1SC,3 Corecooler,42lb inj.
301whp & 300wtq @ 10psi dynojet SAE 106 degrees
ricklmesa is offline   Reply With Quote
Old 01-29-2006, 08:20 PM   #3
Rygen's Avatar
Re: 4.0l Dual cam
Just rumors for now, there have been many threads on this.
2005 Mustang
http://www.powerhouse411.com
http://www.rygen.net/stang
Best 1/4: 10.97@122.09, 1.56 60ft w/4.0 V6
Best 1/4: 11.67@115.45, 1.64 60ft w/5.4 3V
Best 1/8: 7.401@92.77, 1.65 60ft w/5.4 3V
Rygen is offline   Reply With Quote
Old 01-30-2006, 06:58 AM   #4
Re: 4.0l Dual cam
Yeah... alot of those threads were started and or talked in by me... but thanks guys!
Old 03-12-2006, 04:51 PM   #5
RGR
Send a message via AIM to RGR
Re: 4.0l Dual cam
I need to consult my 60* V6 book
There are many european Cosworth parts for this engine family,
so if they are from the same block it could be feasible! Bet I could
do it
PSedit: Hopefully the Cosworth has a forged steel crank, better get that
at the same time. It will need it! My machinist thinks the 4.0 is junk, mostly
because of the bottom end. He's also a real stroker king, he built possibly
the world's first 408W using the 400M crank in a 351. He's made more strokers
than all the V6 shops combined. (all types of Fords from 4 cyl to big block and other brands)
Originally Posted by Flex:
You are the true cam master dude...
RGR is offline   Reply With Quote
Old 03-12-2006, 05:15 PM   #6
Rygen's Avatar
Re: 4.0l Dual cam
do it
Impressive, who is your machinist.
2005 Mustang
Old 03-12-2006, 05:20 PM   #7
RGR
Re: 4.0l Dual cam
The name is John Walker, he works for Taylor's in Terre Haute, IN
There is also a crank grinding shop across the street from him, they
do all his crank work. Everything from stock re-work to welded strokers
I don't think either shop is on the internet...
Old 03-13-2006, 10:36 PM   #8
Rick0636's Avatar
Re: 4.0l Dual cam
RGR, I think where his reasoning might come from is this engine has been bored and stroked about to its limits by Ford, it started as like a 2.6L I believe, the OHC was added like around 10 years ago.
Old 03-14-2006, 07:19 AM   #9
RGR
Re: 4.0l Dual cam
The 4.0 is a different block than the 2.6, 2.8, 2.9, 3.0 series, and is far from maxxed out More later * ...
The reason Walker says they are junk is that he sees lots of them getting
repaired, and I guess he has seen many types of problems. I will ask him
what some of these are and how to avoid them. His "junk" comment was
relative to other less problematic Ford engines, like the 3.8, that was the
context of his comment.
* As for the 4.0 blocks, they have the widest bore spacing I've seen on
anything short of a big block, and bigger than some of those off brand
big blocks. It is 4.76" and theoretically you could get 4.5" bores if it were
sleeved to the max.
If you poured the block I'd guess you could get a 4.100" bore give or take,
the stock bore is 3.95" and you could probably go 60 over no problemo.
I could see some nice high RPM NA setups with a big bore, stock stroke
making some great HP. Get a 4.2-ish OHC motor revving to 7500 and you'll
see some serious power if the heads flow really well. 450 BHP with 300 CFM
and good combustion at least, if the crank holds up
SSS Terminator + Nino Dual Exhaust Kit OR Mac Dual Cat Back? AggieMustang Pre-2005 V6 Mustang 46 01-29-2010 06:03 PM
3.8 V6 Comp Cam Performance Cam nmaraijko Mustang Parts for Sale and Wanted 0 11-15-2006 07:11 AM
what is needed to swap the dual cam v8 mark 8 motor into a mustang gt 1996 MIA1996gt 1996-2004 Mustang GT 1 09-12-2006 09:36 PM
Cam Cores needed for RDMotorsport cam GP RGR Mustang Parts for Sale and Wanted 3 03-05-2005 05:53 AM
09:42 PM
