Head Gasket ?s 95-3.8 - Mustang Evolution
Old 01-25-2010, 06:54 PM   #1
Question Head Gasket ?s 95-3.8
Ok I have a 95 vert with 3.8 no issue with Head gaskets, Was this a hit or miss issue? Is there anything I should be aware of or do for PM to not incur a head gasket problem? Love the car and runs real good with no issues just a PM nut.
Carl
cgff is offline   Reply With Quote
Old 01-26-2010, 01:07 AM   #2
v6stang04's Avatar
Re: Head Gasket ?s 95-3.8
when you get the time, check and see if there is any leaks coming from around the heads, if so then thats y you got them. if not, the other owner couldve just had them incase it were to happen, or he changed the heads, just not the gaskets. but do keep and eye on it just to be safe.
04 v6 gun metal grey
bbk cai, bbk 65mm throttle body, bbk shorty headers, straight pipes, 18x9 front 18x10.5 rear rims, gt bumper, red neon underglow, ford racing lsd with t-lok, summit racing tuner
v6stang04 is offline   Reply With Quote
Old 01-26-2010, 12:40 PM   #3
from 94 till mid 96 head gaskets were an issue, im sure some are fine while others are not. if you have not had them replaced and you dont plan to supercharger or mod the car heavy im sure they probably will be fine.
Old 01-27-2010, 06:49 AM   #4
Well I am not planning any heavy mods maybe a cai wheels and exhaust.
The car has no leaks anywhere (except for vert top?) It is a good running car
I have an opportunity to trade towards a 98 coupe Hard top with the dealer I bought it from usual issue though Odometer. same as mine when I bought it
Buyer beware!
Old 01-27-2010, 08:17 PM   #5
big show 98's Avatar
The 95 head gasket will blow out with time. The thread depth in the block for the head bolts is the problem. Go with the 98.
big show 98 is offline   Reply With Quote
head gasket replacement on 04 GT mikeg 1996-2004 Mustang GT 6 12-03-2009 08:56 AM
head gasket... on a seabring? jimmy_beaner The Bar 6 05-06-2008 08:07 AM
leaking head gasket tedness Pre-2005 V6 Mustang 5 03-07-2005 10:06 PM
leaking head gasket...what? tedness The Bar 1 03-07-2005 09:43 PM
Cracked Head or Head Gasket problem DMustanger Pre-2005 V6 Mustang 21 12-17-2003 06:52 AM
02:42 AM
