tires - Mustang Evolution
Old 01-26-2010, 01:38 AM   #1
v6stang04's Avatar
tires
im needing to get new front tires, and i looked at the size that i need, on the tire it says 245/40zr18. now does that mean that is the only tire that will fit on my rim, cause on am i found the same size, just w/o the zr part, will those fit, or would i need the zr part, and what does zr stand for?
04 v6 gun metal grey
bbk cai, bbk 65mm throttle body, bbk shorty headers, straight pipes, 18x9 front 18x10.5 rear rims, gt bumper, red neon underglow, ford racing lsd with t-lok, summit racing tuner
v6stang04 is offline   Reply With Quote
Old 01-26-2010, 05:36 AM   #2
Re: tires
ZR is just the speed rating.
For an 18x9 inch wheel I would recommend at least a 265/35. I personally run a 275/35-18 on my 18x9's on the front and a 295/35-18 on my 18x10 rears.
Old 01-26-2010, 12:00 PM   #3
Re: tires
+1 ^^ the speed rating is just what you want the tire to go speed wise~
Old 01-26-2010, 02:29 PM   #4
upton7's Avatar
Re: tires
When it comes to speed ratings unless your a cop or you think your brian or dom don't worry about it.
Old 01-26-2010, 06:04 PM   #5
Region: Iowa
Re: tires
The only caution I would throw out is that if you are not replacing all 4 tires, it is best to stay in the same general 'speed' category. There are different letters that describe the speed rating and the "general" rule of thumb is that you can deviate 1 speed rating without much problem. The higher speed rated tires will have different handling characteristics (e.g. stiffer sidewalls) in addition to a higher speed limit. If you start to mix and match speed ratings, you may see some squirrly handling.
For example, I would not recommend a "S" tire (112 mph) mated with a "Z" tire (168mph).
NQSperformance
Vendor for:
American Muscle - Maximum Motorsports - Stack Racing - Koni - Tokico - H&R - Eibach - Hawk - Powerslot
John@NQS is offline   Reply With Quote
new tires Fishers Stang Mustang Wheels & Tires 2 06-17-2006 06:07 PM
My new Tires Herbstang Mustang Wheels & Tires 3 04-14-2005 12:21 PM
This is why I keep going through tires! 03redfire cobra Pictures and Videos 18 09-13-2004 08:23 AM
cobras/tires for welds/tires, $$$? tire The Bar 2 02-22-2004 11:11 AM
10:56 PM
