Stock 1/4 mile Time - Mustang Evolution
Old 02-04-2006, 12:14 PM   #1
Stock 1/4 mile Time
Ive just bought a 2001 Mustang v6 with the 5spd mt i wanted to know the stock quarter mile time
Danstang8 is offline   Reply With Quote
Old 02-04-2006, 08:59 PM   #2
DarkShadow's Avatar
Send a message via AIM to DarkShadow
Re: Stock 1/4 mile Time
I think it's somewhere in the 16's...
DarkShadow is offline   Reply With Quote
Old 02-04-2006, 09:55 PM   #3
15.5-16.0 stock with 2.1 60ft in good condition with a good driver
Old 02-05-2006, 12:26 AM   #4
03YellowPony's Avatar
Mid 16's. That's what I ran before the mods..
http://i32.photobucket.com/albums/d4...llowsig7cu.png
Additional mods: MM subframe connectors, NGK IrridiumX plugs, high energy wires.
03YellowPony is offline   Reply With Quote
Old 02-05-2006, 08:08 PM   #5
Thanks do you think i can make it to the mid 14's on bolt ons
Old 02-05-2006, 08:13 PM   #6
you will need to get good at driving and have good conditions along with shave a second off your car.
Gears/Tlok .3
CAI .1
Exhaust .1
UDP .1
Tune .1
thats most with bolt ons~ you can port/polish the intakes and gain a bit more and those numbers are just speculation~ the mods work better together and all of that crap.... you should be able to shave .6 to .7 off your car with all the bolt ons, my old v6 should have been around a 14.714.9 and I had all that was listed all listed above as well as an aluminum driveshaft (no tune though)
Old 02-05-2006, 08:14 PM   #7
they will run mid 15s in a manual with a good driver
Old 02-05-2006, 08:47 PM   #8
No way in hell. Sorry, but unless you juice it, add a supercharger, turbocharger, or do some drastic engine work...14's are outa reach.
Old 02-05-2006, 09:33 PM   #9
slvr2000stang's Avatar
Yes it's possible
Custom Delk motor now DOA
2003 SVT Lightning #1059 of 4270
2000 Vert 4R70W
Only buy from vendors that test and stand behind their products
slvr2000stang is offline   Reply With Quote
Old 02-06-2006, 12:06 AM   #10
Originally Posted by slvr2000stang
Yes it's possible
With just the standard bolt ons? Do tell. How would this happen? Get towed by a z06 Vette? or a Ford GT???
Old 02-06-2006, 03:41 AM   #11
Nite-Mare's Avatar
I'd say nitrous...
Nite-Mare is offline   Reply With Quote
Old 02-06-2006, 06:27 AM   #12
I ran 14.8 in an auto with bolt-ons & a tune.
2000 Vert 4R70W
Old 02-06-2006, 09:16 AM   #13
a00v6stang's Avatar
what about with cams? does anyone think of that as a bolt on? he might as well if he would get:
p/p intake and exhaust
cams
and the rest of the list that spectorv listed, what would he be able to run. tackier tires would help with his 60'.
What would he run?
im doing that with my car, but Im also going to be getting a 11 psi procharger turbo kit, what would I be running and him. I was looking into low-high 13s
It's all about how fast you get from point A to point B, now how you get there
a00v6stang is offline   Reply With Quote
Old 02-06-2006, 09:25 AM   #14
Ported heads & intakes & the right cam would put you in the 13's easy.
2000 Vert 4R70W
Old 02-06-2006, 09:36 AM   #15
a00v6stang's Avatar
thats what I was thinking also, so high 12s are in the reach with a 9psi kit?
Old 02-06-2006, 10:21 AM   #16
Dont dare expect to slap on a few bolt ons and go run mid 14s, it takes time to get good and learn the car in order to push it to its limits. Stock you will probably see 16s~ on average just the way it goes.
Old 02-06-2006, 10:32 AM   #17
THANK YOU!
Old 02-06-2006, 11:04 AM   #18
But..on the same note, it is possible to run 14's with bolt on's.
Old 02-06-2006, 11:46 AM   #19
it is very possible to run high 14s~ in the quarter mile but not easy.
Old 02-06-2006, 02:15 PM   #20
a00v6stang's Avatar
theres a guy running with 9psi running low to mid 14s
Old 02-06-2006, 02:24 PM   #21
I have run high 14's in my auto with the important bolt ons & a tune.
So a 5 spd is capable of it also. Yes I agree there are factors.
Driver skill, track prep, weather conditions.
2000 Vert 4R70W
Old 02-06-2006, 02:34 PM   #22
a00v6stang's Avatar
but yes I would also agree to the factors that everyone is listing. Im sure everyone know these also, but I know that it wont be true that throwing all these parts on and im going to run this thing into what i want, got to break the parts in and practice practice practice...thats what even the most skilled drive or a stock mustang needs to do when putting on parts
Old 02-06-2006, 02:44 PM   #23
a00v6stang's Avatar
where can i find a tach adapter for a sunpro aftermarket tach?
Old 02-06-2006, 02:57 PM   #24
sunpros are not the best brand in the world.... they are probably less acurate than the stock tach FYI. Buy an autometer or dont buy one at all
Old 02-06-2006, 04:15 PM   #25
a00v6stang's Avatar
i got it from a friend for 10 bucks, so just wondering
anywayz, off the tach, what kind of cam would give a stock mustang the best all around performance through the entire rpm range
Old 02-06-2006, 05:48 PM   #26
Cam would depend on several things.
Your plans for the car & what else besides a cam you are going to do.
Basically you need to build a complete package.
2000 Vert 4R70W
Old 02-06-2006, 07:13 PM   #27
a00v6stang's Avatar
I dont know if anyone else remember me posting about me talking doing the stage 2+ from super six motor sports, well im probably going to do it this winter. It will be N/A, all motor. but Im not sure. Im also looking at turbocharging the beast also. I might go stage 3, but dont know if i can run with a stage 3 with out the turbo.....if someone could look into it, I will too, if this would be better to do, or would the stage 2+ also work with a turbo....
Old 02-06-2006, 07:41 PM   #28
Build it for a goal.
I am running an SC designed setup NA & it rocks.
2000 Vert 4R70W
Old 02-06-2006, 07:49 PM   #29
a00v6stang's Avatar
thats what i was thinking about doing, and will probably do that. could a 215/65/r15 fit on the stock rim..
Old 02-06-2006, 07:51 PM   #30
Take your time, do your research, and build it with the best parts you can afford.
2000 Vert 4R70W
Old 02-06-2006, 07:57 PM   #31
a00v6stang's Avatar
I will be going with a stage 2+ kit and if i ever want to put a turbo on it, i will be able to... supersix emailed me back within a half an hour of me emailing them. got to love their service
Old 02-06-2006, 09:03 PM   #32
Tom is a good guy with good stuff
2000 Vert 4R70W
Old 02-06-2006, 10:38 PM   #33
a00v6stang's Avatar
i will be getting the stage 2+ kit from super six at the beginning of summer, and getting a billet cam for it, i will decide on which one later while i can research more.
will a 215 65 r15 fit on the oem rims of a 2000 ford mustang v6?
Old 02-07-2006, 04:46 AM   #34
I believe that is the stock 15" tire size
2000 Vert 4R70W
Old 02-07-2006, 05:04 AM   #35
a00v6stang's Avatar
stock can be two sizes 205 65 r15 or another which would be 225 65 r16 i have the 15s so would 215 65 r15 fit on it?
Track 1/4 mile time 2007STANG Pre-2005 V6 Mustang 1 07-27-2009 04:30 PM
Stock Z06 10 Second 1/4 Mile Run Rocket 442 General Car Discussion 12 12-08-2007 01:46 AM
I Need to know the quarter mile time of my opponet TexaStang Pre-2005 V6 Mustang 27 07-25-2005 02:58 PM
estimated quarter mile time Sublime782 Pre-2005 V6 Mustang 5 07-08-2005 10:28 AM
Quarter mile time for a stock 98 v6 danstang Pre-2005 V6 Mustang 16 06-30-2005 06:22 PM
12:56 AM
