brakes squeal - Mustang Evolution
Old 02-05-2006, 06:04 PM   #1
Send a message via AIM to charkelly9
brakes squeal
I had my brakes changed by a ford dealer around 3 weeks ago.. my car has 25kmiles and yet after having the brakes changed they still squeal really badly. Could the problem be the rotors/? If so how much does re-surfacing of rotors normally cost?
charkelly9 is offline   Reply With Quote
Old 02-05-2006, 06:31 PM   #2
Re: brakes squeal
Rotor brakes squeal...it's part of it. You can try using some anti-squeal compound to see if that will fix it. The only way I'd have my rotors turned is if you have pits or stuff in them that you can see/feel easily.
Old 02-06-2006, 11:54 AM   #3
Re: brakes squeal
they all squeel, the key is knowing a good one from a bad one. It may be metal on metal thats not brake pad/rotor related... i would get them to check it again just to make sure, and you be there next to them while they do incase they half *** it.
Old 02-07-2006, 05:34 PM   #4
Region: Iowa
Send a message via AIM to Horse Send a message via Yahoo to Horse
Re: brakes squeal
All brake jobs should include rotor resurfacing. If you just replace the pads, the pads will wear unevenly and more than likely they will squeel.
If it's just a little squeek at the very end of the stop, then you got cheap pads. Cheap pads always seem to squeak.
4.2L , CAI, BBK 65MM throttle body, 30lb injectors, SSM ported intakes, FLEX 1/2" spacer, RPM big valve heads, Comp roller rockers and cam, ASP-underdrive pulley, GT rear swaybar, & Quad Shocks, Full MM Coilover conversion, 17" Grey Torque Thrust wheels, FMS Aluminum driveshaft 8.8 rear w/ 3.73 gears, Tri-Ax Shorthrow shifter & SPEC stage II clutch w/ aluminum flywheel
Horse is offline   Reply With Quote
Old 02-07-2006, 07:38 PM   #5
Re: brakes squeal
If they are sqeeking then they are not not squeeking which we all know leads to something bad.. im sure... so thats all about making since, which we should and never open soup with out. The name of the game is *********ing after all!
Old 02-07-2006, 07:49 PM   #6
bbunt302's Avatar
Re: brakes squeal
And this, my friends, is the meaning of life. :smoke:
Scary stuff.
Old 02-08-2006, 10:04 PM   #7
Re: brakes squeal
put white lithium grease on the backof the pads and sliders.
HELP WITH BRAKES?!?!? 03GTNEWB 1996-2004 Mustang GT 6 07-15-2008 10:52 AM
I need help with brakes 05RedDevil 2005-2010 Mustang GT 8 02-19-2008 05:02 PM
Brake squeal DarkShadow Pre-2005 V6 Mustang 32 06-16-2006 11:43 PM
brakes.. Fishers Stang Pre-2005 V6 Mustang 14 01-13-2005 06:32 PM
Brakes V6STANG007 Pre-2005 V6 Mustang 23 10-13-2004 04:32 PM
04:34 AM
