Need help badly :( - Mustang Evolution
Old 02-07-2006, 09:08 AM   #1
Region: New Hampshire
Send a message via AIM to Smokedya95stang
Need help badly :(
I suck at wiring and all that stuff so i have no idea what to try, heres my issue.
Last night car started up perfectly just like it always does. This morning car started up perfectly again drove home car ran great. Came back outside maybe 2 hours later put key in ignition and car wouldnt start. I maybe heard a slight pop or something when i turned the key to start. Then alot of the gauges just went haywire. They currently sit way off where their suppost to be at. Like the temp gauge is way off the charts in hot. lol Same with the oil pressure. I started to hear this mad clicking noise in the rear. Thought it was the fuel cutoff or fuel pump I poped the trunk to hear the noise coming from the keyless entry module so I unplugged the battery to stop it. Then I unplugged the module. Plugged the batt back up, still same ****.
What else should I check?
-Charles
Smokedya95stang is offline   Reply With Quote
Old 02-07-2006, 09:32 AM   #2
slvr2000stang's Avatar
Re: Need help badly :(
Has any aftermarket wiring been done?
Any aftermarket electronics?
The slight pop sounds leads me to think an overload or short occured
Custom Delk motor now DOA
2003 SVT Lightning #1059 of 4270
2000 Vert 4R70W
Only buy from vendors that test and stand behind their products
slvr2000stang is offline   Reply With Quote
Old 02-07-2006, 09:47 AM   #3
I installed rear speakers havent gotten to the fronts yet, and installed my amp and woofers. I also unplugged the amp but it still didnt have any effect. Put i never had a problem before with any electrical thing. I've had it for some time also. There are also no freyed wires that could be touching anything.
Its strange, when i put the key to acc mode the radio doesnt even turn on like something is taking power away cause the chime is also alot lower sounding.
-Charles
Old 02-07-2006, 10:59 AM   #4
Danger Dude's Avatar
Sounds like a bad starter solenoid that has hung up and is stuck in the power up position. They use a lot of current and will make everything else not work
Old 02-07-2006, 12:36 PM   #5
Whats the deal with the keyless entry module clicking all the time?
-Charles
Old 02-07-2006, 07:35 PM   #6
Mine did that one day when the passenger side door button was stuck.
Old 04-19-2006, 06:26 PM   #7
johnpittbull's Avatar
Hi, does your car have the factory alarm as well? If so, it might have shorted out internally. Usually, is right in front of the keyless module. Could be wrong on the location, of years and sort. I also agree with Danger Dude, could be a starter solenoid hanging, or sticking ingaged. Pull the starter and get it tested to make sure its that though.
johnpittbull is offline   Reply With Quote
Old 04-19-2006, 06:44 PM   #8
bbunt302's Avatar
Start simple and try cleaning your battery posts and terminals. My LX had similar issues one time, and that was the cause of it.
Scary stuff.
68 302 shakes badly at idle after T5 swap TEvans720 1979-1995 Mustang GT 6 05-14-2010 06:33 PM
website or store needed badly eddie1 1996-2004 Mustang GT 2 11-02-2008 12:48 AM
so how badly would you kill your brother? jimmy_beaner The Bar 30 07-28-2007 03:29 PM
dayum this makes me want nitrous badly Thomas91169 The Bar 7 12-21-2005 04:18 PM
The CIA sucks badly Brent The Bar 1 02-18-2004 06:42 AM
09:17 AM
