Running the V-6 - Mustang Evolution
Old 02-11-2006, 12:00 PM   #1
05STANG's Avatar
Region: Nevada
Running the V-6
Went to Las Vegas Motor Speedway last night for Midnight Mieham 6 runs. I was in the left lane all night. 17 Gals of 91 (wife filled tank to the cap) 15lbs in right rear tire (no posi) Air temp 55 with 15mph head wind (it's always windy there at night)
05STANG
4.0 auto
Y pipe duals
Heavy wheels and tires 18x9.5
with all add ons and sound system 300 extra lbs?
L .467 1/4 16.391 R 1.200 16.459
L .455 1/4 16.107 R .770 16.260
L .564 1/4 16.031 R .570 14.892
L .308 1/4 19.395 R .773 15.985 Tire spin all the way after burn out / last time for that...
L .132 1/4 15.850 R .353 13.686
Best run with cold engine
R/T .121
60 2.41
330 6.01
1/8 10.013
MPH 71.09
1000 12.833
1/ 4 15.650
MPH 89.21
Best run ever new on stock tires 15.330 @ 91
I COULD HAVE HAD A V8
05STANG is offline   Reply With Quote
Old 02-11-2006, 01:06 PM   #2
Re: Running the V-6
you really got to work on that 60ft, and run the cheap gas it will do better.
Pracrtice makes perfect.
Old 02-12-2006, 08:19 PM   #3
ricklmesa's Avatar
Re: Running the V-6
Are you advising him to run the cheaper gas cause he dont have a tune for 91 octane?
Procharger P1SC,3 Corecooler,42lb inj.
301whp & 300wtq @ 10psi dynojet SAE 106 degrees
ricklmesa is offline   Reply With Quote
Old 02-12-2006, 08:50 PM   #4
Re: Running the V-6
if the car is not tunned for the gas then dont run it. If the car is tunned for XX octane then run it.
Old 02-12-2006, 10:58 PM   #5
05STANG's Avatar
Region: Nevada
Re: Running the V-6
I don't mormaly run 91 but lately it seems quality has gone down, I ping on 87 and sometimes on 89? depends on the station not the brand out here.
Old 02-13-2006, 07:36 AM   #6
Re: Running the V-6
if you ping then you probably should run a higher grade to stop it. I would get it tunned ans set it up how you want to be safe when you get the chance.
what should i be running? tigercrazy718 General Mustang Discussion 0 05-19-2010 02:31 PM
We got them running now Brent The Bar 7 02-14-2007 06:46 AM
Running Hotter Than I Like Justin 1979-1995 Mustang GT 10 12-20-2006 04:29 PM
New computer up and running SpectorV The Bar 5 02-17-2005 12:29 AM
New site is up and running 97Stallion The Bar 5 01-17-2005 03:24 PM
12:34 PM
