ARP Head Studs + Headers = :mad: - Mustang Evolution
Old 02-15-2006, 03:42 AM   #1
Kiljosh's Avatar
Hey, well today I got bored and tried installing my headers back on to the stang.
The stock headbolts made it alot freaking easier. I have to kind of slide the headers in behind the ARP headstuds. This makes it very difficult to install them because I can't pull the thing back a little before to get all the bolts threaded.
I spent almost an hour on the driver side, trying to get the gasket, threads, header and bolt all lined up. So I get 4 of 6 bolts started, working insdide out, but the last 2 are not going. I think my headers are warped. The other two primaries lined up beautifully but the 3rd sits about a millimeter too high up on the head. This is trying to make my bolts crossthread, and I hate that.
Does anyone think I will have a sealing problem if...
a)I use the same set of headers, get them to fit at the heads, will they leak at the collectors you think?
b)Could I use gasket sealant on them? I know they get real hot, but would high-temp black or orange be ok?
On the side, does anyone happen to have a set of stock headers/bolts/collector studs? I still need to buy the studs and one bolt to fully install them. I don't want to have to replace them but maybe I will just buy longtubes....
Old 02-15-2006, 06:16 AM   #2
slvr2000stang's Avatar
Re: ARP Head Studs + Headers = :mad:
I am guessing everytime you type head bolts or studs you mean header.
I used locking header bols and they went in with no problem.
Try starting the two ends first a see if the middle lines up.
Custom Delk motor now DOA
2003 SVT Lightning #1059 of 4270
2000 Vert 4R70W
Only buy from vendors that test and stand behind their products
slvr2000stang is offline   Reply With Quote
Old 02-15-2006, 01:46 PM   #3
Kiljosh's Avatar
No I actually meant head studs. They stick out from the heads too much, so when I goto put my headers on I can't just go straight on, I kind of have to slide them in behind the studs, then slide the gaskets in. It is being a *****.
But thanks I will try working in from the outside.
ARP Main Studs Horse Pre-2005 V6 Mustang 6 06-20-2008 10:11 AM
Cracked Head or Head Gasket problem DMustanger Pre-2005 V6 Mustang 21 12-17-2003 06:52 AM
Mad...... Brent Mustang Audio & Video 9 08-17-2003 05:52 AM
02:17 PM
