Looking to add true duals to my new 06 Pony ASAP - Mustang Evolution
Old 02-16-2006, 12:42 PM   #1
Rick0636's Avatar
Anyone done this yet? What parts did you use, thinking I may go with a Magnaflow 4.0L V6 dual exhaust kit. Any experience in this direction?
Old 02-16-2006, 08:24 PM   #2
05STANG's Avatar
Region: Nevada
Re: Looking to add true duals to my new 06 Pony ASAP
Just my opinion, but from what I have read the 4.0 has a decent exhaust to begin with and the engine can only flow out what it takes in. The intake is only a single venturi. If you want the growl go full duals with X or H pipe but it will sound more like a loud 6 than a V8 and you may lose bottom end. If you are going to do heavy mods to engine and intake thats another story. I went with a second factory muffler run into a Y just ahead of the axel, lost nothing, gained the look and V8 growl but its not loud outside and everyone says it sounds great inside.
I COULD HAVE HAD A V8
05STANG is offline   Reply With Quote
Old 02-16-2006, 09:02 PM   #3
Rick0636's Avatar
Thanks, I am going to go with a less restrictive intake, not sure what mods are even available for the 4.0L, it has been around for a long time in Rangers and so forth. Throttle bodies are also one of my favorite mods, as well as C&L mafs etc. I don't expect I will go wild enough to need an X or cat H. I am a little short on modification knowlege for the 4.0, but I had a modified GT and a heavily modified 94 V6 prior to this one. Thanks for the help. I was also a moderator on this site and on 3.8mustang.com for quite a while. Did you cut your bumper cover/valance to accomodate the second pipe, or did you change to a GT bumper cover?
Old 02-16-2006, 09:09 PM   #4
Rick0636's Avatar
Oh, and you are right, a V6 will never quite sound like a 4.6L V8, regardless of what you do, but it can sound better than it does.
Old 02-17-2006, 07:55 PM   #5
05STANG's Avatar
Region: Nevada
V6 valance, my muffler shop cut it exact to match the passenger side. And believe it or not you would be hard pressed at any distance or speed to tell I have a V6, the exhaust is quiet but definately growls like a well muffled V8 all the way. I also get a nice sound out of the intake with the full MMR cold air kit when getting on it.
http://mustanglife.tenmagazines.com/...n-106053-pos-4
Old 02-21-2006, 09:05 AM   #6
Rick0636's Avatar
Its looking like a pretty expensive deal really, kits go from about 450 for a Mac and up. Plus, since I dont' want to cut the stock rear bumper cover that is going to be about 200 plus painting. The axle back low restriction mufflers are looking better all the time.
Old 02-21-2006, 10:23 AM   #7
I can tell you have a v6, they sound nothing ike v8s about the only thing you can do is come close to the sound at idle. Are the 05+ even fire ?
Old 02-21-2006, 09:39 PM   #8
05STANG's Avatar
Region: Nevada
Y Pipe just ahead of axel, into a second stock muffler, 2 chrome rolled tips from Walmart welded to exhaust pipes and valance cut (no painting necessary) $170.00 total including the $30.00 tips all done by a local muffler shop. As I said it's quiet when on the highway has a stock V8 sound at idle and when I get on it, it still has a nice V8 exhaust tone as well as an intake moan. No one has guessed it was a 6 from the sound.
Old 02-26-2006, 12:41 PM   #9
Rick0636's Avatar
I have a set of GT take off axle backs, mufflers, lol, They are on the way with a GT bumper cover in the right color, and I have a bid on a set of Roush side window louvers, might get the matching Roush scoop for her too, depends how money goes. I am going to have my local muffler shop custom make the rest of the pipes and an H for it. They did similar stuff on my 94 V6 for me, and the 86 V6. AIM muffler shop in Burlington, NC.
Old 03-12-2006, 04:48 PM   #10
RGR
Send a message via AIM to RGR
Originally Posted by SpectorV
...Are the 05+ even fire?...
'Fraid so Spec... but that is a good thing.
I posted some general stuff on another similar V6 exhaust post here:
http://www.mustangevolution.com/foru...ers-19951.html
Check that Rick and then we can proceed
I'd personally get some custom pipes bent and add some nice muffs for looks.
Magnaflow always seemed to sound good, but the fact that Ford has chosen
to go ao similar route as GM has for years (behind axle) negates the positive
sound alteration effects of long tailpipes. Not sure what long mid-pipes do...
Originally Posted by Flex:
You are the true cam master dude...
RGR is offline   Reply With Quote
Old 03-12-2006, 04:49 PM   #11
RGR
PS: That is one fine-a$$ looking tail there, 05STANG!!!
Old 03-13-2006, 09:54 AM   #12
Rick0636's Avatar
here are the pics of my car in my gallery with the duals on her http://www.mustangevolution.com/gall...00&ppuser=2755
Old 03-13-2006, 06:26 PM   #13
downtime's Avatar
Looks damn good! I'm still leaning towards cheaping out and cutting my stock panel, but the "finished" look of the GT panel is very nice. Did you get yours from Diversified off of Ebay?
Come Join The Mineral Gray Mustang Registry, Click here!
See more at 05sixpack.com
C&L CAI;XCAL2;Bamachips 93-Perf Tune;True Duals w/x-pipe
GT Bullits;GT Scoop;12" LeMans Stripes;SS Side Louvers
downtime is offline   Reply With Quote
Old 03-13-2006, 08:59 PM   #14
05STANG's Avatar
Region: Nevada
Looks just like a GT to me with the Pony gas cap. From the rear is it a V8 disguised as a V6 or a V6 disguised as a V8. LoL
Old 03-13-2006, 09:53 PM   #15
Rick0636's Avatar
I can't remember the name of it, he calls himself something wholesale he is out of MI. Its all in what you want and like. My Roush hood scoop and window louvers should be here tomorrow. Well, the louvers and scoop got here first thing today, before I even got out of bed I heard a ring on the doorbell, and they were waiting, no hurry right now to open the boxes or anythiing, can't afford to get them painted for a while anyway. Oh well. I will get them put on soon. I looked up the seller of the bumper covers and GT mufflers, its Cascotech on ebay.
99-04 v6 true duals (help!) CHILE10_STANG Pre-2005 V6 Mustang 14 06-22-2009 08:04 PM
92 5.0 GT cutting CATS off....TRUE DUALS kneith 1979-1995 Mustang GT 6 06-19-2009 09:53 AM
how would true duals sound millastang Pre-2005 V6 Mustang 13 09-29-2007 11:01 PM
True Duals Taywi Classic Mustangs 10 12-09-2006 03:30 PM
Time for True Duals 01mineralgrey6 Pre-2005 V6 Mustang 5 03-22-2004 07:59 AM
01:42 PM
