04 3.9 REBUILD KIT - Mustang Evolution
Old 02-04-2010, 10:43 PM   #1
Zebs5408's Avatar
04 3.9 REBUILD KIT
Im having trouble finding a good quailty one.....any recommendations? i need it to include ALL gaskets, rings, seals, bearing! techinaclly i know a FULL rebuild kit would come with pistons but im pretty sure i just need gaskets and the other stuff! anyway i just wanna browse whos got some sites for me?
04' mustang 3.9 40th Anniversary Edition- (V2 Vortech Supercharger, 38# injectors, 3.73 gears w/ T-lok, Predator Diablo, Mac cold air intake, Port & polished upper AND lower intake manifold, Mac Long Tube Headers, Mac o/r H pipe, flowmasters, 2.5 flowmaster tips)
03' Mustang GT (20" Cobra R's, 40 series Flowmasters)
Zebs5408 is offline   Reply With Quote
Old 02-04-2010, 10:45 PM   #2
Re: 04 3.9 REBUILD KIT
Summit racing has a lot of rebuild kits.
Old 02-04-2010, 10:53 PM   #3
Flatlander Racing - Ford Engine Rebuild Kits
Old 02-04-2010, 10:58 PM   #4
900 for a rebuild kit? That's lame. It's just as lame for my 2.3L at 700 bucks. Yet, on summit a rebuild kit for a 460 is only 350, 500 if you want it forged.
Unfortunately, I checked and summit doesn't have a kit for ford v6s T all. That's even more lame.
I'm sure you could piece together a kit for less than the 900 on that site.
Old 02-04-2010, 11:04 PM   #5
upton7's Avatar
i bought both of mine from summit and they were around 200
Old 02-04-2010, 11:09 PM   #6
That's what I figured, you could piece stuff together for that price, but I wasn't sure how lazy he wanted to be, lol.
Old 02-05-2010, 04:49 AM   #7
96mustang21's Avatar
if i was in your situation which i have been many times lol, i would just buy another engine i looked on car-parts.com in goergia for you and found a motor out of an 04 with 17,121 miles on it for 650 bucks and theres others with low miles for around the same this specific one has a 6 month warranty. now with your old engine just strip it down and rebuild it up little by little the way you want to like a race engine port and polish and shave the heads forge the rotating assy build it to hold a decsent amount of boost or a 4.2 stroker theres alot you could do its up to you and what you want this is what i have done a couple times just my 2 cents the site is car-parts.com
96 v6 bottom end, sc heads, eaton m90, sc tb, bbk headers,custom tru dual 2.75 exhaust H-pipe flowmaster 40s, sc 8 rib belts,egr delete,5 speed, etc etc.
96mustang21 is offline   Reply With Quote
Old 02-05-2010, 09:20 AM   #8
Zebs5408's Avatar
i have priced them for around that! i think your right....+1 for newbie!
Old 02-05-2010, 11:16 AM   #9
upton7's Avatar
any motor i buy no matter how new it is i rebuild it at least gaskets
Old 02-05-2010, 02:30 PM   #10
im different every motor ive ever bought from a salvage yard has been tested before it went in the car which should be done any way i do a comp/vac test for head and intake gasket problems and check around the heads valve covers and oil pan for leaks if it checks out in it goes i was always told if it isnt broke dont fix it save the money now i could see if it had high mileage then no matter how good the motor checked out i would change gaskets to be safe but ive always bought engines that had less than 60000 miles and im proud to say that every car ive swapped the engine in i still see being drove around town and yes the town is small lol
Old 02-07-2010, 06:52 PM   #11
Zebs5408's Avatar
anyone have a good deal on a 3.9? i DO NOT WANT a 3.8, i know samething blah blah i just dont want one lol! what if i drop a 4.2 put a f150 in there lol? or what a min, 3.9 & 4.2 is the same block right just different crankshaft and pistons? so it would be cheaper to buy a 4.2 block w/ pistons than to take my 3.9 block and bore it out and find new pistons right? i have a feeling my bottom end is the problem so why not just snatch a 4.2 block w/ crank and pistons out of a 97 f150 and put my heads and up on top of it and roll? i know not that simple but would that work? its been along day please forgive me lol
Old 02-08-2010, 06:29 AM   #12
that is what i originally wanted to do a 4.2 stroker but i figured id get more hp/tq out of a 9.0 compression block with a sc top end n e way i searched a little and found this it might help Ford Ranger 3.8L Engine Swaps
Old 02-09-2010, 12:51 AM   #13
Send a message via AIM to VCS_SSSTANG
3.8/3.9/4.2 are all the same block, so if you find a shortblock and put your top end on it it will work.
VCS_SSSTANG is offline   Reply With Quote
Cylinder Head rebuild kit snake428CJ 1979-1995 Mustang GT 2 04-03-2008 09:59 PM
donor rebuild vs current engine rebuild cash05_mustang Pre-2005 V6 Mustang 2 07-01-2006 02:09 PM
Supercharger rebuild Falcon Pre-2005 V6 Mustang 6 07-22-2004 02:53 AM
5.0 rebuild. Smokedya95stang 1979-1995 Mustang GT 3 03-15-2004 08:13 AM
02:08 AM
