Hey Guys! - Mustang Evolution
Old 02-05-2010, 01:30 PM   #1
Hey Guys!
I'm new here, my name is Tim and I am 20 years old, living in Orlando, FL. I am getting a 2006 v6 stang very soon, it's satin silver, and a 5 speed. Just wondering, what beginning mods I should do...I already have in mine, bbk air intake, and flowmaster exhaust. But what else should I start out with? Thank you! =)
06stang is offline   Reply With Quote
Old 02-05-2010, 01:35 PM   #2
96mustang21's Avatar
Re: Hey Guys!
congrats im 21 and im from tampa fl im missing the weather down there someone done a write up on this already heres the link
http://www.mustangevolution.com/forum/t5654/
96 v6 bottom end, sc heads, eaton m90, sc tb, bbk headers,custom tru dual 2.75 exhaust H-pipe flowmaster 40s, sc 8 rib belts,egr delete,5 speed, etc etc.
96mustang21 is offline   Reply With Quote
Old 02-05-2010, 01:36 PM   #3
Re: Hey Guys!
Yeah, I saw that..but I can't find pulleys for an 06 v6 anywhere...and I am guessing for the gears to get 3.73?
Old 02-05-2010, 01:40 PM   #4
blackonblack's Avatar
Re: Hey Guys!
yeah 3.73, tlok. and then a tuner.
2004 3.9L v6
Black on black on black
MAC Cold Air Intake, 4.10 gears + T-Lok, SCT Tuner, dual H piped flowmaster super 40's
blackonblack is offline   Reply With Quote
Old 02-05-2010, 01:43 PM   #5
Re: Hey Guys!
ya 4.10s are kinda steep for a 5 speed when i do my gear swap it will be with 3.55s and i seen pullies some where i think ill check around and see
Old 02-05-2010, 01:49 PM   #6
Re: Hey Guys!
heres the link for a underdrive pully
2005 2006 2007 2008 2009 Mustang Under Drive Pulley at V6MustangStuff.com
Old 02-05-2010, 02:12 PM   #7
Re: Hey Guys!
Ahh, that does look familiar..I need a certain belt for it? Or is stock ok.. Thanks man.
Old 02-05-2010, 02:20 PM   #8
Re: Hey Guys!
You'll probably find that even after getting a CAI, you'll need a tune. Most CAI's for the 05+'s require a tune so the car doesn't run too lean. If you buy a CAI that doesn't require a tune, it is most likely not going to be as effective.
The 05+'s are very sensitive regarding air/fuel...that's why many manufacturers require a tune after install. If you install a CAI that requires a tune and don't tune it, you could damage your engine.
It's worth it to buy a decent CAI and get a tune...the gains for the 4.0 v6's are way better than for the pre 05 v6's.
Old 02-05-2010, 02:37 PM   #9
Re: Hey Guys!
welcome
Old 02-05-2010, 02:41 PM   #10
Re: Hey Guys!
Yeah Ive heard before they need a tune with an intake..wasn't sure if it was true or not. What do you think is the best out of these...
http://www.summitracing.com/parts/DBL-U7140/
Hypertech 41050 - Hypertech Power Programmer III - Overview - SummitRacing.com
http://www.summitracing.com/parts/JET-15043/
Old 02-05-2010, 02:44 PM   #11
Re: Hey Guys!
welcome
Thank you!
Old 02-05-2010, 04:21 PM   #12
upton7's Avatar
Re: Hey Guys!
go to Mustang Parts & Performance - American Muscle they have underdrive pullies sct and diablosport tuners 3.73 ring and pinion tloks intakes and short throw shifters.
And if you ask what shifter to get be prepared to get opinions you just have to deside if you want a real smooth shift which is the mgw shifter or if you want a harder shift which is the steeda tri ax and probably pro 5.0.
When it comes to tuner get one that makes custom tunes not preloaded.
When getting the gears get the ford racing ones. I'm pretty sure you got a 7.5 rear end.
pullies i would get the bbk ones because they are a little cheaper.
Old 02-05-2010, 06:10 PM   #13
Re: Hey Guys!
Originally Posted by 06stang View Post
I'd go with either SCT or Diablosport. But as upton said, don't buy pre-loaded (canned) tuners. Go through a professional vendor such as VMP Tuning, BamaChips or Brenspeed for custom tunes. They will be tunes specifically for your car, based off what you want. You could do a dyno tune if you wanted, though a dyno tune isn't really necessary for a v6 with bolt ons.
Hey guys Cali_edition New Member Introductions & Greetings 5 05-13-2009 02:13 PM
Hey Guys 6w5 New Member Introductions & Greetings 5 08-22-2008 08:07 AM
Hey Guys! will_04 New Member Introductions & Greetings 9 02-04-2005 02:59 PM
Hey guys... Kuplex The Bar 19 08-23-2004 11:12 AM
03:52 AM
