Seafoam 96 mustang - Mustang Evolution
Old 02-06-2010, 08:22 AM   #1
Seafoam 96 mustang
I'm thinking about trying the seafoam out. I have never used this stuff myself, and I'm pretty sure it has never been used in this car before. It is a 96 mustang v6 with 225,000 miles. I drive it 70 miles every day, has been very reliable, but it just feels like I'm carrying a boat ancor behind when going up hill and taking off and has a rough idle. I was getting 23mpg about 3 months ago, and now I'm getting 18-19mpg trying to keep RPM's below 2000 rpm. Basically, I want too know if 225,000 miles is to high and risky to use seafoam.
96Mustang0250 is offline   Reply With Quote
Old 02-06-2010, 10:01 AM   #2
Re: Seafoam 96 mustang
With that many miles, expect a really good amount of carbon buildup and oil and deposits. My only concern with that many miles would be if a chunk of crud flaked off and plugged an injector or something odd like that.
It will clean the engine out pretty good, so expect a LOT of smoke.
Old 02-06-2010, 10:21 AM   #3
Yes, I was also concerned about a chunk...I figured it would smoke bad. Would this plug up the converters?
Old 02-06-2010, 11:28 AM   #4
Zebs5408's Avatar
ur about to find out if u have any holes in your exhaust lol
04' mustang 3.9 40th Anniversary Edition- (V2 Vortech Supercharger, 38# injectors, 3.73 gears w/ T-lok, Predator Diablo, Mac cold air intake, Port & polished upper AND lower intake manifold, Mac Long Tube Headers, Mac o/r H pipe, flowmasters, 2.5 flowmaster tips)
03' Mustang GT (20" Cobra R's, 40 series Flowmasters)
Zebs5408 is offline   Reply With Quote
Old 02-06-2010, 11:54 AM   #5
I've read, to put 1/3 bottle in the tank, 1/3 in the oil, and suck 1/3 through the brake booster vacuum. I don't want to put this stuff in the oil, so how much should i use in the tank? Should I do this with a full tank, half tank...
Old 02-06-2010, 12:40 PM   #6
Blogger
Blogger
rickf73's Avatar
Send a message via MSN to rickf73 Send a message via Skype™ to rickf73
I have a 87 f150 that has been running bad for Bout a year. Took it to ford and they could not get it to run better. I put a can in a full tank of gas and that did the trick. Back to running right again.
rickf73 is offline   Reply With Quote
Old 02-06-2010, 01:40 PM   #7
OsirisGuy's Avatar
Seafoam is one of the best things you can do for your car. The instructions for it are right in the bottle. I hear a lot of 1/3 in the tank, 1/3 through a vacuum line... I'm sure there are online "how to's" in case you get confused.
Usually they say to wait for ~65,000 miles; not that it hurts the car before that mileage, but it won't do much since the internals and system is 'pretty clean' up until ~70k miles.
OsirisGuy is correct
OsirisGuy is right
2002 Mustang GT
Old 02-12-2010, 10:32 PM   #8
The actual way you want to do it would be to put a full can in your gas tank after a fill up, and half a can directly into your oil (via top of the valve cover). It will cause your exhaust to smoke a little, but shouldn't be anything too major. Although, I wouldn't recommend running seafoam in your engine for no more than 300 miles before an oil change.
19Delta is offline   Reply With Quote
Old 02-14-2010, 01:59 PM   #9
upton7's Avatar
Both mustang engines i tore down didn't look to bad in the bottom end it was just the pistons had alot of carbon buildup on em which is normal. Both are over 100,000 miles
Seafoam advice... DarkShadow General Car Discussion 29 07-10-2008 12:29 AM
Finally used the seafoam Herbstang General Car Discussion 12 04-10-2008 12:31 AM
follow up to seafoam... white 98 gt 1996-2004 Mustang GT 16 08-03-2006 06:57 AM
seafoam or something else.. white 98 gt 1996-2004 Mustang GT 1 07-19-2006 11:51 PM
02:00 AM
