Engine Swap/ Engine Shakes - Mustang Evolution
Old 02-23-2006, 06:32 PM   #1
Ok, here's my deal.... I recently put a 89 thunderbird sc engine in my 94 mustang but I took the blower off and swapped my mustang on it. The car runs not too bad right now but I did use my flywheel and my harmonic balancer. The car was shaking really bad and I was told the harmonic balancer needs to be neutrally balanced so I took it out and removed the weight from it and now it's pretty good and only shakes a little at 1500 rpms but other than that it's ok. Would it be shaking because of my makeshift harmonic balancer or is it because of the flywheel and it being weighted in some way also? Thanks
too_cool_mitch is offline   Reply With Quote
Old 02-28-2006, 12:49 PM   #2
RGR
Send a message via AIM to RGR
Re: Engine Swap/ Engine Shakes
The flywheel has to be neutral balance too, you can take the weights off the fly
also, maybe even without pulling the motor... I did not know the HB had a weight
you could remove, I thought it was cast in there! Never seen one like that,
all the ones I saw were 1 piece.
Originally Posted by Flex:
You are the true cam master dude...
RGR is offline   Reply With Quote
Old 02-28-2006, 02:01 PM   #3
the HB will be neutral if its solid round, if it has an indentation on it you will know its weighted, but you dont remove the weight. The flywheel also has to match.
engine swap midnightrider_s Pre-2005 V6 Mustang 1 10-22-2009 09:49 AM
engine swap 1989 to 1992 4 cyl engine dannyc1992 General Mustang Discussion 0 02-08-2008 01:59 PM
Want to swap my v6 engine for a v8 Justin-Heath Pre-2005 V6 Mustang 10 12-08-2006 03:56 PM
Engine Swap? V6Stang33 Pre-2005 V6 Mustang 25 02-18-2005 04:09 PM
mustang engine kinda shakes?! mexor The Bar 29 09-17-2003 09:01 PM
10:56 PM
