blown v6 need help - Mustang Evolution
Old 02-08-2010, 04:55 PM   #1
Region: Arkansas
Send a message via AIM to wifeyv6stang Send a message via MSN to wifeyv6stang Send a message via Yahoo to wifeyv6stang
blown v6 need help
thanks man ive been searching though the site for a week now finally joined you guys have great advice and B.A. cars....... I a have seemingly usual problem... got a project for my wife a 95 3.8 and one the gas milage sucks.... and now the damn thing locked up on my it was ticking before and i thought it could have been a rod bearing... so now i need a new..rebuilt of reman motor.... any suggestion on price to rebuild myself or aveage shop cost plus and sorry for so much at once will a 99-04 fit in the 95 and work properly>
wifeyv6stang is offline   Reply With Quote
Old 02-08-2010, 04:58 PM   #2
Region: Arkansas
Re: blown v6 need help
lowflyn got my squared away i think but any help would be greatly appreicated
Old 02-08-2010, 07:17 PM   #3
Zebs5408's Avatar
it should be a straight drop! the only difference is the cylinder heads the engines are the same! i would go with the 99-04 v6 do to the performance difference! theres 30-40+ HP do to the split port heads, you will feel a major difference in performance and gas mileage should be the same, you will be much happier with the 99-04 v6....trust me! good luck im about to swap out my 3.9 for another 3.9 so if u need any help or wanna share some info let me know bro! take care and God bless....ohhh and WELCOME
04' mustang 3.9 40th Anniversary Edition- (V2 Vortech Supercharger, 38# injectors, 3.73 gears w/ T-lok, Predator Diablo, Mac cold air intake, Port & polished upper AND lower intake manifold, Mac Long Tube Headers, Mac o/r H pipe, flowmasters, 2.5 flowmaster tips)
03' Mustang GT (20" Cobra R's, 40 series Flowmasters)
Zebs5408 is offline   Reply With Quote
Old 02-09-2010, 07:37 AM   #4
the great thing with the v6 mustangs are the engines are cheap, very cheap. You can replace the engine or rebuild it for little money its just a matter of determining if you want a junk yard motor with lower miles that runs to just drop in and try or rebuild your current engine. The issue with a rebuild is labor to put it back together and the hopes that they put it together right.
Old 02-09-2010, 10:51 AM   #5
upton7's Avatar
Well if you know what your doing the rebuild should go fine
Old 02-09-2010, 06:25 PM   #6
Zebs5408's Avatar
everyone makes mistakes lol, i rather buy a used motor with low miles and check everything out and only buy with a 90 day warrranty but make sure u install it the first week!
Old 02-09-2010, 10:53 PM   #7
big show 98's Avatar
Find a used 97-98 engine & it will be a direct swap. If you go with the 99-04 engine you will have to do some mods to make it work, but it can be done.
big show 98 is offline   Reply With Quote
Old 03-05-2010, 01:20 PM   #8
97Stallion's Avatar
Correct, the 99+ mustangs used a returnless fuel rail, to use a 99+ motor you need to modify your exsisting fuel rail.
Living one day at a time!
Blown V6 Falcon Pictures and Videos 24 01-28-2008 03:59 PM
blown headgasket? or not? blackturbobeast 1979-1995 Mustang GT 5 12-22-2007 08:41 AM
Needs to get blown iwannagofast Pre-2005 V6 Mustang 0 09-14-2007 07:55 PM
BLOWN BLOCK GINO Pre-2005 V6 Mustang 13 09-13-2006 02:35 PM
Both welds blown... :\ Low Sun Pre-2005 V6 Mustang 6 06-26-2006 04:35 PM
04:37 PM
