reving high - Mustang Evolution
Old 02-28-2006, 11:52 AM   #1
red pony V6's Avatar
Send a message via AIM to red pony V6
reving high
my car has been reving high recently and it's really freakin' annoying. everytime i stop at a light or whatever my engine still revs up to about 1500 or 2000 rpms for a few seconds, then it comes down to normal. what is causing this?
1998 V6
true dual flows
CAI
MGW shifter
and slow as hell...
red pony V6 is offline   Reply With Quote
Old 02-28-2006, 12:49 PM   #2
Re: reving high
my 01 did this, its the idle decay rate. You can potentialy fix it by cleaning the MAF sensor with electronic NO residure contact cleaner (cleans on contact no need to wipe, and you shouldnt wipe)
and replace/clean out the idle bypass valve (located on the backside by the firewall right behind the throttle body if not bolted to it. Small little thing.
After this reset the computer (or unplug the neg battery terminal while you do this)
if this doesnt work then you can have it altered with a tune.
Old 02-28-2006, 01:06 PM   #3
Herbstang's Avatar
Re: reving high
When I got my 04 it did the same thing, I went through all the cleaning of the MAF. Which didn't help !!! I got a SCT chip & had the idle decay rate lowered and that solved the problem
Old 03-03-2006, 12:58 PM   #4
Send a message via Yahoo to CreativeCustoms
Re: reving high
I never had that problem on my Mustang, but it did happen on my 97 Ranger. I cleaned the MAF sensor and reset the computer and its seemed to settle down for a while. Then it returned when I had the A/C on while I was at an idle. So I had it tuned. This seemed to fix the problem. Hope that helps.
-CreativeCustoms
:wstupid:
1996 v6 3.8L --- soon to be a 302!
Help its Stock!
CreativeCustoms is offline   Reply With Quote
High beams Rascal Pre-2005 V6 Mustang 2 03-20-2010 08:51 AM
Is this dude high? iwannagofast 1996-2004 Mustang GT 12 09-26-2009 11:34 PM
The High Came and Went bluemustang The Bar 28 03-01-2007 02:33 PM
A little high? n8r The Bar 10 02-13-2006 01:14 AM
Reving while in Park or Neutral? Ibanezplayer272 Pre-2005 V6 Mustang 12 05-31-2004 01:15 AM
09:23 PM
