GT500 wheels - Mustang Evolution
Old 02-14-2010, 06:05 PM   #1
SaturnMan8227's Avatar
Send a message via AIM to SaturnMan8227
GT500 wheels
Hey guys I'm trying to get me a set of 07 Shelby GT500 wheels. 18's would be sick. However I can't seem to find any that will fit the 99-04 Mustang. Any help would be awesome.
Thanks
~Dan
SaturnMan8227 is offline   Reply With Quote
Old 02-14-2010, 06:06 PM   #2
Re: GT500 wheels
AM has them for the 99-04...
http://www.americanmuscle.com/99-04-...html#shop-by13
Old 02-14-2010, 07:32 PM   #3
Re: GT500 wheels
they dont have the 07 style like i have pictured above
Old 02-14-2010, 07:41 PM   #4
Re: GT500 wheels
That's because you didn't have that pictured when I responded. Foo
Old 02-14-2010, 11:41 PM   #5
Re: GT500 wheels
I did some searching...but I found nothing.
19Delta is offline   Reply With Quote
Old 02-15-2010, 12:25 AM   #6
Send a message via AIM to VCS_SSSTANG
Re: GT500 wheels
You have to buy the 05+ ones and use spacers or whatever....
VCS_SSSTANG is offline   Reply With Quote
Old 02-15-2010, 07:18 AM   #7
Re: GT500 wheels
yea spacers will setup 05+ wheels to work correctly on pre 05 cars
Old 02-15-2010, 12:26 PM   #8
Re: GT500 wheels
Greatg dose anyone know what size wheel spacers I need for the front and rear?
Old 02-15-2010, 01:46 PM   #9
Re: GT500 wheels
Get me the backspacing and offset
Old 02-15-2010, 01:57 PM   #10
Re: GT500 wheels
The backspacing looks like around 7.2" (183.4mm) and the offset is +50mm.
Old 02-15-2010, 02:11 PM   #11
Re: GT500 wheels
According to americanmuscle.com they are 18x9.5 with an offset of +50mm and a back spacing of 7.22"
that means 9.5 - 7.22 = 2.28
2.28 is the amount of rim that stick outwards from the rotor mounting surface.
For 99-04 mustangs this needs to be around 3.00 (2.89-3.10) inches~ so if my math is correct you will need a .75 inch spacer~ (example 03 cobra rim 17x9 6.11 backspacing = 2.9 front spaced)
That will put you around 3.0-3.1 inches front spaced which is where you need to be, having 9.5 wide you may have rubbing issues as most recommend no wider than 9 in the front but they will work~ just FYI your front sway bar will be rubbed on at full lock of the steering wheel.
For the rear you can go more to stick the tire out for a more aggressive look if you wish. I would not to past 3.75 inches. That means it would require a rather large spacer... around 1.5 inches. The safe limit to ensure no fender lip hitting is 3.5 inches so in that case you can do 1.25 inch spacer in the rear...
Not sure if that size of a spacer is safe~ i have no info on them.
for tires on a 9.5 hmmmm I would probably aim for a 285 wide tire.
Old 02-15-2010, 02:53 PM   #12
Re: GT500 wheels
So I need a .75in - 1.25 for them to work?
Old 02-15-2010, 03:06 PM   #13
Re: GT500 wheels
I would buy the rims first. If they are for the 99-04 mustangs, I would think the spacing would be set already to not require spacers.
If you need a spacer, then you can order them after test fitting the rims. And if you need that big of spacers, you're going to need new, longer wheel studs.
Old 02-15-2010, 03:15 PM   #14
Re: GT500 wheels
The thing its thbat that the 07-09 Shelby wheels are not made for the 99-04 mustang. which I asked if any knows what size wheel spacers I need for the front and rear
Old 02-15-2010, 03:28 PM   #15
Re: GT500 wheels
Edit:
Never mind, I see you said that the site didn't have the version you wanted.
Therefore, I would say you can't run them on your car as a 1+" space is not a good idea.
Old 02-15-2010, 03:51 PM   #16
Loc: Austin,TX
Re: GT500 wheels
That looks pretty good.
Old 02-15-2010, 04:10 PM   #17
hottcobra's Avatar
Re: GT500 wheels
They make one inch spacers that bolt to the factory studs and have it's own studs and they will work fine.
Old 02-15-2010, 04:26 PM   #18
Re: GT500 wheels
I know there are hubcentric spacers, but that is still a lot of extension for your Axel. That's a lot of added leverage being placed on your bearings and such.
Old 02-15-2010, 04:38 PM   #19
Re: GT500 wheels
I guess it's one of those choices of looks vs. **** breaking/wearing out.
Old 02-15-2010, 06:49 PM   #20
00STANG00's Avatar
Send a message via AIM to 00STANG00 Send a message via Yahoo to 00STANG00
Re: GT500 wheels
try blueovalindustries.com
SUCK MY DUST
00STANG00 is offline   Reply With Quote
Old 02-15-2010, 09:35 PM   #21
Re: GT500 wheels
tried blue oval; they only make the shelby wheels for the 05+
Old 02-16-2010, 07:24 AM   #22
Re: GT500 wheels
.75 wheel spacer seems to be what you would need AT LEAST to fit them right front and back, I just said 1.25 for the rear to make it look more aggressive, but as said above... thats a lot of spacer.
Old 02-17-2010, 10:33 AM   #23
Re: GT500 wheels
Ok thabks guys. Might just get the wheels for when I do care shows. Seems like it be to much of problem for daily driving
Shelby GT500 Wheels Question... sector550 Mustang Wheels & Tires 8 04-14-2008 09:55 AM
11:29 PM
