Dyno - WTF - Mustang Evolution
Old 03-12-2006, 07:52 PM   #1
Dyno - WTF
I had my car dynoed the other day for free through my school. Unfortunatly I couldn't go but my friend took my car. The numbers I got are ridiculous in my mind. Anyone have any thoughts on what's up? BTW it's a 2002 auto V6 running a SCT 93 octane tune.
-Denver
2002 Mineral Grey GT, 5-speed: MGW short throw, JLT CAI: SOLD
2002 Electric Green V6, Auto: SOLD
greenpony02 is offline   Reply With Quote
Old 03-12-2006, 07:58 PM   #2
MarkuzLS1's Avatar
Send a message via AIM to MarkuzLS1
Re: Dyno - WTF
I'm no expert, but I'd say that sounds about right. At 15% drivetrain loss that comes out to 141.2 at the flywheel.
I like turtles.
MarkuzLS1 is offline   Reply With Quote
Old 03-12-2006, 08:25 PM   #3
slvr2000stang's Avatar
Re: Dyno - WTF
It looks low to me.
Custom Delk motor now DOA
2003 SVT Lightning #1059 of 4270
2000 Vert 4R70W
Only buy from vendors that test and stand behind their products
slvr2000stang is offline   Reply With Quote
Old 03-12-2006, 08:32 PM   #4
MarkuzLS1's Avatar
Re: Dyno - WTF
Originally Posted by slvr2000stang
It looks low to me.
What did Ford rate those cars at?
I like turtles.
Old 03-12-2006, 08:37 PM   #5
Re: Dyno - WTF
he also has an SCT tune. I was ~150rwhp stock add 12 or so for the tune
2000 Vert 4R70W
Old 03-12-2006, 09:02 PM   #6
Monkey's Avatar
Re: Dyno - WTF
1999+ had 190bhp
Old 03-12-2006, 09:09 PM   #7
MarkuzLS1's Avatar
Re: Dyno - WTF
Yeah, I guess it does sound a bit low. Get a tune-up. Maybe replace the cats. Sounds like something may be awry.
I like turtles.
Old 03-12-2006, 09:33 PM   #8
Re: Dyno - WTF
WAAAAAAYYYYYYYYYYY TO LOW!!!!!
when i just had an intake, exhaust, and pulley i put down 183/224 (176/216 SAE)..........BEFORE A TUNE. now figure ~12 for the tune, that puts me at ~190rwhp/230rwtq.........however, after the tune, my best was 174rwhp/205rwtq SAE..........but that was in a 105* shop with 30% humidity........on the pre tuned pull it was about 65* and 15% humidity
Kyle is offline   Reply With Quote
Old 03-12-2006, 09:41 PM   #9
Re: Dyno - WTF
I Know! I can't figure out if something is wrong or if they screwed something up when dynoing it. My car feel like it always has so I think they did something wrong
-Denver
Old 03-12-2006, 09:43 PM   #10
Kiljosh's Avatar
Re: Dyno - WTF
EDIT* Oh your name is Denver, wow I feel dumb.
Old 03-13-2006, 12:14 AM   #11
Re: Dyno - WTF
Thats definatly way to low.
neatofrito1618 is offline   Reply With Quote
Old 03-13-2006, 04:32 AM   #12
Ibanezplayer272's Avatar
Send a message via AIM to Ibanezplayer272 Send a message via MSN to Ibanezplayer272
Re: Dyno - WTF
Ya thats to low.
2007 Windveil Blue Mustang GT
Mods : Intake, Stubby antenna
Rolls are for fat chicks
Ibanezplayer272 is offline   Reply With Quote
Old 03-13-2006, 05:13 AM   #13
Danger Dude's Avatar
Re: Dyno - WTF
OK here is the real world slapping you in the face. Reality can suck but you should be closer to 150 at the very least. SCT tuned for premium usually nets 10 Hp but that is not a given and many things could also be happening. Poor quality gasoline. You need a tune-up, faulty oxygen sensor, clogged cats but that is less likely because of the age of the car or a dirty MAF sensor.
Here is the thing. As a veteran of many dyno pulls you need to change plugs each time before you go. I change them actually just before I get on the dyno. One bad or irregular plug can cause you to loose anywhere from 8 to 25 HP. If you have a couple of bad or irregular plugs it could mean a huge loss in HP
Old 03-13-2006, 07:44 AM   #14
Re: Dyno - WTF
the dyno could have been off.... it has to be set correctly doesnt it?
Old 03-13-2006, 08:21 AM   #15
Re: Dyno - WTF
Possibly!!! Dyno's do need Calibrating, Something that I dont think was asked is What type of dyno was it was. Typically Mustang (MD) dyno's will show up to 10% lower numbers than a Dynojet dyno.
Old 03-13-2006, 05:09 PM   #16
Re: Dyno - WTF
Thanks Corey, thats what I was looking for. I'll have to check my plugs etc. I wasn't expecting anything spectacular on the dyno I just thought the 120 was a little on the low side. Everyone else at the dyno seemed to get resonable numbers I just figured something could have gone wrong. I've been to the track and ran about 16 flat so I figured that 120 HP at the wheel could get me there that fast. Hopefully i'll find the problem if there is one and wait another 6 months to a year and have the school pay for it again.
-Denver
Old 03-13-2006, 06:04 PM   #17
Re: Dyno - WTF
A properly calibrated Mustang Dyno is very accurate like the one @ Delk Performance.
Also putting an auto on the dyno is different from a 5 spd.
You need it in 3rd gear and not downshift when you hit it.
2000 Vert 4R70W
Old 03-13-2006, 07:07 PM   #18
Re: Dyno - WTF
That is somewhat true. What some dyno guys do is let you go through the gears and once you hit around 60-70 the car will not downshift and then you hit the throttle. The other way is to start in 3rd. When Jerry tuned my car at Team Ford he did it the first way I mentioned
The Mustang Dyno as Kirk mentioned is probably the most accurate dyno out there.
Old 03-13-2006, 09:42 PM   #19
Re: Dyno - WTF
Jerry sets the EEC to shift to third early, locks the TC & locks out any down shifts.
I have a tune just like that for the dyno
2000 Vert 4R70W
Old 03-14-2006, 08:43 AM   #20
RGR
Send a message via AIM to RGR
Re: Dyno - WTF
Go thru everything under the hood, loose connections, vacuum lines, and the
plugs like Corey mentioned. Also, it could be a bad plug wire(s) causing this.
I agree, it looks low. Quite.
Originally Posted by Flex:
You are the true cam master dude...
RGR is offline   Reply With Quote
wtf is this?? meteorachick The Bar 17 04-25-2006 06:47 PM
Wtf?! steedav6builder The Bar 9 09-28-2004 06:13 AM
Wtf?? 01mineralgrey6 Mustang Audio & Video 14 09-15-2004 03:17 PM
NE DYNO DYNO DAY 11/8 BlueDonkey Regional Mustang Discussion 9 11-13-2003 01:51 PM
04:59 AM
