Oil Dipstick Question - Mustang Evolution
Old 03-12-2006, 09:36 PM   #1
Kiljosh's Avatar
How is the dipstick tube attached to the engine? Is it kind of like the fitting for the EGR off the header? The tube kind of slips through a nut and screws into a bung?
Reason I ask is mine popped out while putting by driverside header in. Anyone know anything about them?
Old 03-13-2006, 09:16 AM   #2
Danger Dude's Avatar
Re: Oil Dipstick Question
The dipstick slides into a hole in the block and has a bracket that attaches uses #5 exhaust header/manifold bolts with nuts that keeps it in place.
Old 03-14-2006, 03:14 AM   #3
Kiljosh's Avatar
It just slides in?
How would you go about installing a new one?
Old 03-14-2006, 04:34 AM   #4
It just slides in?
Yes just slide it in. You just nee to make sure you are at the right angle and it will just slide in.
Old 03-14-2006, 04:45 PM   #5
Kiljosh's Avatar
Do you know what the end of it is supposed to look like? I have a feeling it snapped off in there, it doesn't look slideable as it is. My end is kind of bell shaped, guessing maybe it snapped off on the ridge so it doesnt slide to far in.
If that makes any sense.
Old 03-14-2006, 06:04 PM   #6
There should be maybe 4 to 6 inches from the end to the flared stop point on the stick. They are prone to breaking if they are shoved around a lot and then you have the broken piece in the block!!!
Old 03-14-2006, 06:31 PM   #7
Kiljosh's Avatar
How do you think I could get that 4 to 6 inches of scrap metal out of there? Maybe a pair of needlenose pliers? Any idea how much a new dipstick tube costs? This sucks, everytime I solve a problem with this car 2 more pop up...
Old 03-14-2006, 08:45 PM   #8
You could try needle nose but the gods honest truth is if there nothing sticking out to grab you will have to take the oil pan off. A dip stick is probably pretty cheap.
Old 03-14-2006, 09:39 PM   #9
Kiljosh's Avatar
Damn, k thanks man, always a help. I really didnt wanna take the pan off but things happen...
Old 03-16-2006, 03:55 PM   #10
Kiljosh's Avatar
Good news, I was able to get at the piece after putting my car p on ramps in the front, Slid under there and worked it out real carefully with a flathead, then grabbed it and it came right out.
So glad I didn't have to drop that pan, that is a beeeyotch.
Engine Oil Question drkchocolate07 Pre-2005 V6 Mustang 6 07-17-2008 10:21 AM
redline differential oil question Horse Pre-2005 V6 Mustang 0 03-13-2007 09:16 PM
Oil Dipstick-94 GT Conversion to 69 FB emarsagl 1979-1995 Mustang GT 1 08-09-2006 08:35 AM
Oil pan question... lowflyn Pre-2005 V6 Mustang 9 03-15-2006 05:14 PM
Dipstick fell off: Rellik Pre-2005 V6 Mustang 14 08-10-2003 02:39 PM
03:33 PM
