Need to hit the mid 14's - Mustang Evolution
Old 03-12-2006, 10:58 PM   #1
My car is a 2003 mustang v6 auto. and want to hit the mid 14's this is what i had in mind
*long tube headers
*offroad h pipe and exhaust
*cold air intake
*Udp(not sure which ones)
*sct flash tuner
*4.10 gears with t-lok
*Port and polished intakes with bbk throttle body
*18 inch saleen wheels with performance nito tires
*eibach lowering springs
*rear seat delete
will this get me into the mid 14's
will a shift kit help?
SonikBlueStang is offline   Reply With Quote
Old 03-12-2006, 11:45 PM   #2
timpryor's Avatar
Re: Need to hit the mid 14's
shift kit will help, but IMO i would go with a custom tuned chip from justin vs a genaric tune
those wheels will KILL YOU
"The LORD shall judge the people:judge me, O Lord, according to my righteousness, and according to mine integrity that is in me." PSALM 7:8
In Texas? check out www.lonestarstangs.com
timpryor is offline   Reply With Quote
Old 03-13-2006, 12:11 AM   #3
Yes it will. I agree you should get a xcal2 and tune your shift points instead of getting a cheap shift kit.
neatofrito1618 is offline   Reply With Quote
Old 03-13-2006, 07:46 AM   #4
18s will slow you down leave the oem 15s and put tires on the back ones for traction.
Old 03-13-2006, 09:29 AM   #5
whats the best rim size will the 17 inch cobra wheels do
and what do you think im gonna run with thoose mods?
Old 03-13-2006, 10:29 AM   #6
you can run any wheel/tire you want bug weight slows the car down. Every pound of rotating mass is nearly equal to 10 pounds of dead weight. So if you increased your wheel's weight by 30 pounds thats like adding 300 extra pounds of dead weight to he car~
With all of those mods you should be a second faster if not more, Stock time are 16.0~
Old 03-13-2006, 10:53 AM   #7
there are also ultra lite wheels from steeda which ones do you think are better the 17 x 9(first pic), the 18 x 9(first pic), or the 18 x 9.5(second pic)
Old 03-13-2006, 12:40 PM   #8
wheels are all personal preference, you have to pay the price for getting 18 inch rims, they are not THAT much heavier but they are heavier. I wouldnt worry about it to much though, get an aluminum driveshaft to help offset the extra weight (an aluminum driveshaft is 10lbs lighter, and its 10 rotating lbs)
Old 03-14-2006, 08:50 AM   #9
RGR
Send a message via AIM to RGR
Dude, you could take the wheel money, spend that on real mods,
and go mid 14's with a cam and tune. Get the shift points modified
with the tune.
Going Fast > Looking Good
You already got a Mustang, so it looks good. I'd rather have fast car
that looks really good than a slow car that looks awesome.
Use your street racing winnings to buy the wheels...
Did I say that out loud???
2:
Originally Posted by Flex:
You are the true cam master dude...
RGR is offline   Reply With Quote
Old 03-14-2006, 07:15 PM   #10
i know i have a superchager only running 5 psi i get mid to low 14's everytime on bad street tires hope this helps
jedwards242000 is offline   Reply With Quote
Old 03-14-2006, 07:27 PM   #11
MarkuzLS1's Avatar
Send a message via AIM to MarkuzLS1
4.10 gears
a posi-trac differential (or whatever it is y'all call 'em)
some sort of drag radial
and hit it with as much nitrous as it'll take.
I like turtles.
MarkuzLS1 is offline   Reply With Quote
Old 03-14-2006, 07:33 PM   #12
I liek gramer
WhiteStang99's Avatar
we call them a T-Lok.
Old 03-14-2006, 08:50 PM   #13
MarkuzLS1's Avatar
posi-trac sound better :p
I like turtles.
Old 03-14-2006, 09:28 PM   #14
Originally Posted by MarkuzLS1
4.10 gears
You dont need nitrous to run mid 14's. Bolt on's, a flasher, and 4.10's should be enough(with a decent driver).
Old 03-14-2006, 09:34 PM   #15
MarkuzLS1's Avatar
But nitrous is about as expensive as a single bolt-on.
I like turtles.
Old 03-14-2006, 11:40 PM   #16
I liek gramer
that's a matter of opinion! Why have a posi-trac? Is there a negi-trac??
Traction-Lock, alright, that makes sense.
Old 03-15-2006, 09:15 AM   #17
they work differently in most cases, aka detroic locker vs ford tlok. The name some time justifies the means.
Old 03-15-2006, 12:08 PM   #18
I've paid over $600 for my nitrous stuff and i dont even have a bottle warmer yet, and i pay $60+ a month for nitrous.
Mid pipe with mid mufflers? Tompkins 2005-2010 Mustang GT 5 03-27-2010 12:26 PM
Which Mid Pipes To Go With???? Gt.Vert 1996-2004 Mustang GT 12 02-18-2010 08:29 AM
mid-high 14's tigerfan2771 Pre-2005 V6 Mustang 25 04-02-2008 11:18 PM
F-14's Shredded Brent The Bar 9 07-04-2007 07:44 PM
mid pipes 96-98 GT silverstangboy Mustang Parts for Sale and Wanted 1 12-15-2006 05:31 PM
07:40 PM
