Cant unscrew TPS - Mustang Evolution
Old 03-13-2006, 12:49 PM   #1
Ibanezplayer272's Avatar
Send a message via AIM to Ibanezplayer272 Send a message via MSN to Ibanezplayer272
Cant unscrew TPS
I cant unscrew my Throttle Positioning Sensor. I just have to use a screw driver right? all the screw drivers I have are to long and I cant get a good grip on it considering the screw driver is horizontal and I cant get good force to unscrew it, I believe this is the reason im idling high and I have to get it off... any ideas you guys?
2007 Windveil Blue Mustang GT
Mods : Intake, Stubby antenna
Rolls are for fat chicks
Ibanezplayer272 is offline   Reply With Quote
Old 03-13-2006, 01:12 PM   #2
Danger Dude's Avatar
Re: Cant unscrew TPS
Yes it is just 2 screws. Here is a trick take the screwdriver put it in the screw and hit the back end of the screw driver solid and it will loosen the screw. if you have a screwdriver with a area near the base of the handle that you can get a wrench on it will also help. You also might need a second set of hands to help you.
Old 03-13-2006, 09:37 PM   #3
Thanks bro, ill try it tomorrow, headed off to sleep.
Old 03-14-2006, 08:55 AM   #4
RGR
Send a message via AIM to RGR
I've had to grind the heads off most of those, and I've done alot of them.
Originally Posted by Flex:
You are the true cam master dude...
RGR is offline   Reply With Quote
TPS Performance Benjytps New Member Introductions & Greetings 11 08-09-2008 10:16 PM
tps sensor carlosc Pre-2005 V6 Mustang 9 05-11-2007 12:32 AM
TPS?? 98StangGT 1996-2004 Mustang GT 10 08-22-2006 03:00 AM
TPS question... 98GreenStallion Pre-2005 V6 Mustang 15 03-02-2005 07:22 PM
TPS Tuning Kiljosh Pre-2005 V6 Mustang 12 01-30-2005 12:15 PM
05:44 AM
