Rear mounted turbo? - Mustang Evolution
Old 03-13-2006, 10:56 PM   #1
Rear mounted turbo?
Someone help me out here. Squires turbo make a case for themselves (of course), but they make it seem like it has the benefits of a turbo and a supercharger in one rear mounted system. Is this too good to be true, nothing special, or just plain crap?
http://www.ststurbo.com/
HotRod.riguez is offline   Reply With Quote
Old 03-13-2006, 11:38 PM   #2
Re: Rear mounted turbo?
I have never seen that before... that is pretty wild.
Old 03-13-2006, 11:42 PM   #3
I liek gramer
WhiteStang99's Avatar
I think I've seen or heard of it before, but know **** about it.
Old 03-14-2006, 06:45 AM   #4
MarkuzLS1's Avatar
Send a message via AIM to MarkuzLS1
STS turbo'd LS1 Camaro makes 617rwhp on a Mustang dyno. Link here. It's a writeup on the whole build. Enjoy.
I like turtles.
MarkuzLS1 is offline   Reply With Quote
Old 03-14-2006, 11:39 AM   #5
DarkShadow's Avatar
Send a message via AIM to DarkShadow
Looking through the site, the kits appear to be very professionaly made. Very bolt onish with most of the things you need (if you get the upgrades). Expect to pay out the anus tho.
DarkShadow is offline   Reply With Quote
Old 03-14-2006, 05:29 PM   #6
Nite-Mare's Avatar
These systems work but they rely on a pump for the oil and the pumps are prone to fail.
Nite-Mare is offline   Reply With Quote
Old 03-14-2006, 05:52 PM   #7
dark's Avatar
Send a message via AIM to dark Send a message via Yahoo to dark
^don't all turbo systems rely on a pump for oil?
I don't own a mustang at the moment
dark is offline   Reply With Quote
Old 03-14-2006, 07:57 PM   #8
Region: Hawaii
It's most likely for the drain back. It should use the engine oil pump to send oil to the turbo, but because the turbo sits lower than the oil pan the drain back must be moved with a pump, because gravity feed wouldn't work.
99 Atlantic Blue V6- SOHC 4.6 swap, Tremec 3650, 8.8 rear end/ Flowtech Ceramic LT headers, off-road x-pipe, Spintech side exit exhaust. K&N drop in filter, removed snorkel, 18x10, 18x9, Anthracite Bullitt Replicas 295-35's, 265-35's. Eibach Pro-Kit springs, M&M Camber Plates
wrecked2001 is offline   Reply With Quote
Old 03-14-2006, 08:26 PM   #9
DarkShadow's Avatar
Yes the engine pump pumps it to the turbo, and then gravity feeds it back to the oil pan on most. But since that is a remote, it would require a pump to get it back to the pan.
Old 03-14-2006, 09:06 PM   #10
Monkey's Avatar
all electric pumps are prone to failure The STS remote turbo utilizes the oil pump in the oil pan to send oil to the turbine unit. A pump then pressurizes the oil to return to the pan.
rock lights mounted up SrATEX Pictures and Videos 7 03-29-2006 08:28 PM
New stud mounted roller rockers GT-Eater Pictures and Videos 2 09-07-2005 07:41 PM
FS OR TRADE: 18x9 replica bullit wheels *new* never mounted Suprman Mustang Parts for Sale and Wanted 8 02-01-2005 11:11 AM
Rear mounted Turbos.......? Seph The Bar 17 12-24-2004 04:08 PM
Got my 275/40/ZR17 Kuhmo Ecsta 712s mounted on my 8" Bu Rick0636 Mustang Wheels & Tires 6 12-03-2003 09:34 PM
04:54 PM
