old V6 question - Mustang Evolution
Old 03-14-2006, 05:20 PM   #1
Send a message via Yahoo to plstktnkr2
old V6 question
My motor came with a cam thrust plate and spring puck for camshaft do I need both and how do you put the damn thing in with the motor on a stand?
[SIGPIC][/SIGP
1983 4 eyed GLX Convertible
1966 Lincoln Continental Convertible
1985 Lincoln Town Car Hearse
Local "10-hole Mafia" Don
member of the "Anti-Cowl" club
plstktnkr2 is offline   Reply With Quote
Old 03-14-2006, 06:09 PM   #2
Danger Dude's Avatar
Re: old V6 question
So you have the engine mounted on the stand using the Bell housing bolt holes!!! Well you need to put the engine stand mounts to the front accessories holes. I know that is not what you wanted to hear but that is what is needed. I have had to spin a motor around a few times
Old 03-15-2006, 06:53 PM   #3
Re: old V6 question
ok the cam rides on the puck, and the puck against the timing cover and you accomplished this how??? If I need to why not demount from stand and install the puck with the timing cover forcing it down?( this was how it was dissassembled ) hell the rest of the engine is done
[SIGPIC][/SIGP
Old 03-16-2006, 06:36 AM   #4
RGR
Send a message via AIM to RGR
Re: old V6 question
ok the cam rides on the puck, and the puck against the timing cover and you accomplished this how??? If I need to why not demount from stand and install the puck with the timing cover forcing it down? (this was how it was dissassembled ) hell the rest of the engine is done
You've had that cam for 2 years now
You gonna dyno that beast Rick? I'd like to see what it all does!
After all, I did the intake and cam for ya. Love to see what the
4 barrel does on a healthy V6 stroker! Would you list the specs
for the peeps? I don't even remember the cam specs or carb size.
Originally Posted by Flex:
You are the true cam master dude...
RGR is offline   Reply With Quote
Old 03-16-2006, 06:49 AM   #5
Re: old V6 question
OK I am a bit confused. Are you talking about the front or the rear of the engine??? I thought you were talking about the rear of the engine not the front. Now If I got this right you should just install it withg the timing cover forcing it down.
Old 03-17-2006, 05:27 PM   #6
Re: old V6 question
RGR if I could find a dyno that wouldn't charge me an arm and a leg for dyno testing I would have figures(the only dyno that wanted job was 900.00 bucks and wanted motor all day). Had a place refuse me because it was a V-6!!!!
[SIGPIC][/SIGP
Old 03-18-2006, 12:50 PM   #7
RGR
Re: old V6 question
You need to find a good chassis dyno, lots cheaper. Go down to UNCC
and have David Vizard tune on it
Old 03-19-2006, 10:20 PM   #8
Re: old V6 question
if the motor was in the car it would be no probem , but I wanted the carb jetted and tuned before it went in the car
BTW cam button is in and did it with engine on stand no biggie
now tomorrow final assembly !!!
[SIGPIC][/SIGP
Old 03-20-2006, 01:17 PM   #9
RGR
Re: old V6 question
Hope we get that 300 HP it was designed for!
What carb are you running Rick? I forget...
Old 03-22-2006, 05:34 PM   #10
Re: old V6 question
I will be running an Edelbrock 500CFM 4 bbl with mech. secondaries
[SIGPIC][/SIGP
Old 03-23-2006, 07:08 AM   #11
RGR
Re: old V6 question
Cool, is it possible to put an extra spring on the secondary linkage so you can
feel when it is being engaged? I'd do that, carbs that have a "feel" for the
secondaries help you get better mileage and you also know where the power is.
Old 03-24-2006, 08:52 PM   #12
Re: old V6 question
maybe i will see if it has some feel to it
[SIGPIC][/SIGP
thanks for the help one more question JAYS MUSTANG Pre-2005 V6 Mustang 3 09-16-2006 10:07 AM
Sub Question graystangguy06 Mustang Audio & Video 9 06-26-2005 12:56 PM
another 3.8-4.2 question. Horse Pre-2005 V6 Mustang 9 07-16-2004 09:37 PM
Question 98VroomVroom Mustang Audio & Video 1 03-28-2004 01:29 PM
Question 98VroomVroom Mustang Wheels & Tires 1 03-27-2004 10:20 AM
08:21 PM
