Traction Control Q - Mustang Evolution
Old 03-14-2006, 08:16 PM   #1
Region: Hawaii
Traction Control Q
The 99 i just picked up dosen't have traction control, however it does have a dummy plug on the back of the shifter bezel next to the lighter. Is this the connector for traction control? If so does it run all the way to the ECU?
99 Atlantic Blue V6- SOHC 4.6 swap, Tremec 3650, 8.8 rear end/ Flowtech Ceramic LT headers, off-road x-pipe, Spintech side exit exhaust. K&N drop in filter, removed snorkel, 18x10, 18x9, Anthracite Bullitt Replicas 295-35's, 265-35's. Eibach Pro-Kit springs, M&M Camber Plates
wrecked2001 is offline   Reply With Quote
Old 03-14-2006, 08:30 PM   #2
232stang01's Avatar
Send a message via AIM to 232stang01 Send a message via Yahoo to 232stang01
Re: Traction Control Q
About the only way to know for sure is to pop the shifter bezel off.
232stang01 is offline   Reply With Quote
Old 03-14-2006, 09:57 PM   #3
Region: Hawaii
I removed the bezel and there is a connector there connected to a dumy plug, would that be the traction control connector?
Old 03-14-2006, 11:38 PM   #4
I liek gramer
WhiteStang99's Avatar
I have a 99 V6 and don't have anything except two "coin holders" that are a ***** to keep clean.
Old 03-15-2006, 09:18 AM   #5
if you dont have traction control just adding the plug wont give it to you. You would need more I do believe.
Old 03-15-2006, 10:09 AM   #6
Herbstang's Avatar
Without the traction control module it's just a extra wire so leave it be Here's a link to a wiring diagram http://randrspecialty.com/autoelectr...stall_Diag.png
Old 03-15-2006, 11:13 AM   #7
traction control is a total waste of money unless you live up north, the whole reason it came into existence. I hate it.
The other day I was going down the road in 3rd fixing to merge so I accelerated a bit and BAM traction control came on slowed my butt down ... pissed me off.
Old 03-15-2006, 04:15 PM   #8
you need to have ABS to have traction control.
Old 03-15-2006, 05:36 PM   #9
Region: Hawaii
I am doing a swap and 01 gt has Traction control and ABS. I would like to swap everything over. Also i am planning on moving either to Iceland or Germany so ABS and traction control would be nice.
Old 03-16-2006, 08:32 AM   #10
they still blow chunks in the snow but it does help
Old 03-16-2006, 10:49 AM   #11
It's especially helpful if you have a V6 and don't have a limited slip differential.
-Denver
2002 Mineral Grey GT, 5-speed: MGW short throw, JLT CAI: SOLD
2002 Electric Green V6, Auto: SOLD
greenpony02 is offline   Reply With Quote
Old 03-18-2006, 02:19 PM   #12
232stang01's Avatar
Traction control sucks. I wouldn't bother with it.
Old 03-20-2006, 05:57 PM   #13
Region: Hawaii
OK, say i don't hook it up, will it always be on? Will I have to disable it some how. Is there a procedure to diable it?
Burn out-traction control? occhopperman27 1996-2004 Mustang GT 19 08-21-2009 02:19 PM
Traction control? braumab General Mustang Discussion 30 12-21-2007 01:50 PM
Motor acts like traction control is active ArmyStangGT 1996-2004 Mustang GT 6 09-29-2007 10:42 PM
ABS and Traction control light on rugman1969 1996-2004 Mustang GT 1 09-30-2006 03:09 PM
traction control greenpony02 Pre-2005 V6 Mustang 28 05-02-2005 09:57 PM
06:15 AM
