opinions on brakes... - Mustang Evolution
Old 03-16-2006, 04:05 PM   #1
dark's Avatar
Send a message via AIM to dark Send a message via Yahoo to dark
13 inch rear brake upgrade
this kit is advertised as "13 inch cobra brake REAR upgrade" and "superior to the 11.65 inch cobra brake"
is this a legit upgrade? or is in not possible or even dangerous to use 13 inch brakes on both front and rear?
opinions?
I don't own a mustang at the moment
dark is offline   Reply With Quote
Old 03-16-2006, 04:07 PM   #2
dark's Avatar
Re: opinions on brakes...
p.s.- i'm not buying brakes off ebay for ANY price. just researching. if this is doable, then i'll just buy a custom kit from a site sponsor
Old 03-16-2006, 06:30 PM   #3
To run a 13 inch rotor on the back of your car you're gonna need like 14 or 15 inch rotors on the front. Unbalanced braking will lead to your untimely demise.
Old 03-16-2006, 06:51 PM   #4
dark's Avatar
alright then. i'll just get the standard cobra upgrade with the 11.65 rear
[/thread]
Old 03-16-2006, 07:07 PM   #5
Well I mean wait and see what other ppl say. That's just what I see in my opinion.
Old 03-16-2006, 07:18 PM   #6
dark's Avatar
alright. but i've only got 17x9 rims, and no desire to go bigger just for bigger brakes
Old 03-16-2006, 07:22 PM   #7
bbunt302's Avatar
He's right, you want your front brakes to have more stopping power than your rear. I'd just do the standard Cobra stuff.
Scary stuff.
Old 03-16-2006, 08:55 PM   #8
even if it uses 13 inch rotors in the back you have one less piston on the rear caliper, due to pressure bias you will have less fluid pressure at the rear brakes.
Old 03-17-2006, 10:10 AM   #9
yea the rear will stop better but they wont outpower the front. I wouldnt upgrade the rear brakes though, they dont look any bigger than the OEM ones (no one will notice) but if you can get the brackets from ford for cheap and some good rotors it wont cost a lot.
My advice is to get oem cobra/mach1/bullitt brakes for the front and stainless steel lines. Then get a set of GOOD bear rotors (not cheap-o rotors that will warp) you can get BADASS decela bear rotors for 400 (for the front) they are two peice and are the badness or you can spend 140~ or so and get good ones.
I would NOT get slotted and drilled unless they are a GREAT brand and wont warp (have warranty or something on it) slotted is as far as I would go other wise.
Got my brakes... crazeflier07 Pre-2005 V6 Mustang 13 03-31-2008 12:21 PM
I need help with brakes 05RedDevil 2005-2010 Mustang GT 8 02-19-2008 05:02 PM
brakes/suspension plans... opinions A5295 1979-1995 Mustang GT 0 10-15-2007 10:14 AM
Help with Brakes 98StangGT 1996-2004 Mustang GT 3 12-28-2006 01:39 PM
Brakes V6STANG007 Pre-2005 V6 Mustang 23 10-13-2004 04:32 PM
05:47 AM
