exhaust piping size - Mustang Evolution
Old 03-18-2006, 04:36 PM   #1
exhaust piping size
what size of pipe should i use 2.5 or 3.0 my car is completely stock plan on gettin intake programmer and pullies my friend told me 2.5 for a stock v6 is good 3.0 is too much what do yall think
SonikBlueStang is offline   Reply With Quote
Old 03-18-2006, 04:49 PM   #2
232stang01's Avatar
Send a message via AIM to 232stang01 Send a message via Yahoo to 232stang01
Re: exhaust piping size
2.25", unless you plan on a blower or turbo setup.
232stang01 is offline   Reply With Quote
Old 03-18-2006, 05:06 PM   #3
yeh, 2.25 is fine. That's what I have run on mine all the way back.
Old 03-18-2006, 06:11 PM   #4
will i loose power with 2.5 inch pipes or what will happen
Old 03-18-2006, 06:15 PM   #5
On a stock car, you won't notice a difference between the 2. About the only thing 2.5 over 2 1/4 would do is reduce your backpressure and lower your torque slightly but raise your horsepower. Of course I'm talking about in insignificant measurements of horsepower.
Old 03-18-2006, 06:22 PM   #6
so theres no diffrence between the 2.25 and the 2.5 will i loose or add in the 1/4 mile with the 2.5
Old 03-18-2006, 06:26 PM   #7
You're not gonna get a difference in the quarter either way IMO. The gains/losses between the two are so insignificant it's not even worth worrying about on a stock car. If you are planning on building the engine or going with a forced induction system sometime, then the 2.5 will give you better gains in the future.
Old 03-18-2006, 08:42 PM   #8
slvr2000stang's Avatar
2.25 is better suited for a mild setup.
That is what my old exhaust was and worked well.
Custom Delk motor now DOA
2003 SVT Lightning #1059 of 4270
2000 Vert 4R70W
Only buy from vendors that test and stand behind their products
slvr2000stang is offline   Reply With Quote
Old 03-18-2006, 10:28 PM   #9
until you have a good bit of power 2.25 is perfectly fine, if memory serves me right the exhaust 2.25 inch piping is not a problem until 300rwhp~
Old 03-18-2006, 10:52 PM   #10
jimmy_beaner's Avatar
Region: Iowa
I had 2.5" straight pipe mated with 3.5" tips, and it worked out just fine for me... so either way you go is fine. But think seriously about the power adder thing... cause you may want to, but you may also not have the means to get there.
Old 03-19-2006, 06:59 AM   #11
RGR
Send a message via AIM to RGR
Spec may be right on, but the #'s I have used all the time are 300 BHP, at the crank.
Our Even-fire V6's may get more out of the 2.25" pipes than a V8 does, we've got the
even fire advantage, and adding a crossover is a good bet for any nearly maxxed-out
exhaust system.
A quick ROT chart for exhaust system sizing...
(ROT = rule of thumb)
2.25": up to 300 BHP
2.5" : up to 400 BHP
3" : over 400 BHP
These will overlap somewhat, but these general guidelines work well
for Mustang use, and the available systems. It also assumes the use
of mandrel bent tubing, so get good quality pipe bending.
Originally Posted by Flex:
You are the true cam master dude...
RGR is offline   Reply With Quote
Old 03-19-2006, 05:35 PM   #12
I_luv_HP&trq's Avatar
Send a message via AIM to I_luv_HP&trq Send a message via MSN to I_luv_HP&trq
friend of mine has 2.25" after the cats to the muffler, then after his flowmasters he has 2.5" that goes into 4" tips. it sounds great for a stock 6.
99 Cobra: flowmasters, 18x9.5 cobra R's, soon to be tuned and geared. daily driver
99 V6:in avatar, Mac Cai, true duals/flowmaster 40's ,UDP, custom tuned, bullitt suspension 18" wheels...taken by mother nature
I_luv_HP&trq is offline   Reply With Quote
Old 03-19-2006, 05:41 PM   #13
I need to get a new clip of my exhaust since the exhaust upgrade.
2000 Vert 4R70W
exhaust
Wheel size & tire size help needed for newbie rayramos Mustang Wheels & Tires 14 09-21-2009 11:45 AM
tma turbo piping (hot and cold side) Kyle Mustang Parts for Sale and Wanted 1 10-27-2008 07:55 AM
Turbo Piping! SerbStang Pre-2005 V6 Mustang 10 03-05-2008 12:36 PM
latest pictures of intake piping... whipster24 Pictures and Videos 19 03-24-2005 10:41 AM
Exhaust pipe size for 2004 ??? Black Panther Pre-2005 V6 Mustang 10 08-14-2004 12:02 PM
01:00 AM
