Clutch Problem! I think!! - Mustang Evolution
Old 03-19-2006, 10:24 PM   #1
Scoot99V6Stang's Avatar
Send a message via AIM to Scoot99V6Stang Send a message via Yahoo to Scoot99V6Stang
I have a Centerforce Dual Friciton clutch. Now 3 days after installing it my throwout bearing started singing again for me. Now after about 5 months, if I hold the clutch to the floor and rev it above around 2500 my car begins to lunge forward! Also, I just had my ranny rebuilt about 1500 miles ago. Now the problem is, it has a hard time going into gear. It like hits and then it will fall in. I sometimes have to SLAM it to ge into reverse or first to take off, once I take off it still shifts rough, but a little better! Now could all this be a clutch cable problem. Maybe the clutch pedal isn't completely engaging or disengaging the clutch? Should I start out by getting an adjustable clutch cable to see if that will fix it? IDK what to do, I'm hoping that is the problem, especially with the freshly rebuilt tranny still giving me problems, before the tranny was rebuilt I was having the same problems. Could it be the clutch or clutch cable? Thanks guys. Any ideas would be greatly appreciated!!!
Scoot99V6Stang is offline   Reply With Quote
Old 03-19-2006, 11:29 PM   #2
Re: Clutch Problem! I think!!
what did you torque the pressure plate bolts to
jedwards242000 is offline   Reply With Quote
Old 03-20-2006, 12:33 AM   #3
We used the German torque method of Gudentite! I have no idea. LOL
Old 03-21-2006, 04:39 PM   #4
bump
Old 03-21-2006, 05:45 PM   #5
they have to be correct to much or to little can cause problems. You cant do mods like this or motor work without doing it right. The flywheel may have nothing to do with it either. just one of those try and see... and hope you get it right.
Old 03-21-2006, 09:48 PM   #6
well i did that the first time i installed my clutch and i had the same problem you are having. i took the trans back out and everything looked ok, so i torqued the pressure plate bolts down to proper spec and everything is working great now, i love the clutch. also while you have the trans out go ahead and replace the pilot bearing and throwout bearing while your in there if you already havent.
clutch disc problem 1996v6stang Pre-2005 V6 Mustang 6 07-16-2010 10:33 AM
new clutch problem??? bluestang1724 Pre-2005 V6 Mustang 3 07-31-2007 04:46 PM
downshifting rumble...clutch problem?? maximus 1996-2004 Mustang GT 21 05-29-2007 05:27 PM
Shifter clutch or tranny problem??? PA6shooter Pre-2005 V6 Mustang 10 04-28-2005 08:15 AM
New Clutch (Problem) PuReHeLL Pre-2005 V6 Mustang 8 01-17-2005 12:29 AM
12:36 AM
