Spark Plugs - Mustang Evolution
Old 03-22-2006, 11:54 PM   #1
megax29's Avatar
Send a message via AIM to megax29 Send a message via Yahoo to megax29
Spark Plugs
I got 61k on my car and I it still has the original plugs. I want to change them soon, but I want to do it. I was waiting till I had internet access so I could find a step by step guide on how to do it since I'm not a mechanic. Anyone know where I can find one. Also I read in a hot rod mag that the preferred choice for modern hot rods was Bosch's Platinum 4+, everyone else has told me to go for Motorcraft's Platinum plugs. What should I go for? What's the difference and sh*t? I've kinda set eyes on Bosch's wires, what do you guys think?
V6 Midnight Black
CAI w/ K&N Filter, Tokico Complete Suspension kit, Single Flowmaster w/ turndown, GT rear sway bar.
megax29 is offline   Reply With Quote
Old 03-23-2006, 08:32 AM   #2
Re: Spark Plugs
go with the OEM ford plugs, trust me they are perfectly fine and probably better than most of those other brands. Get whats supposed to be in it, copper or what not. Changing them is pretty darn easy.
Start on the driver's side. Find the spark plug closest to you, you can trace the spark plug wires to find it. DO NOT remove all of the spark plug wires, you remove them ONE at a TIME. Once you find the first spark plug pop the wire off of it by turning it side to side and pulling out, take your time they will come off.
Now use the spark plug socket and any extensions needed with a ratchet and DOUBLE CONFIRM that the ratchet is removing the plug, not tightening it. Slowly break it loose and remove it. Gap the new plug correctly, double check the gap, and put a bit of anti seeze on the threads (NOT a ton just a coat) and ease it in, it does not need to be super tight, I think its liek 15ftlbs~ (or close) so a snug is all it needs, the heads are aluminum so DO NOT over tighten. Place a bit of the conductor greese on the spark plug boot (the end of the wire that goes on the plug) and pop it back on, you will hear the click and you can pul it a bit to confirm its on good.
Continue by doing the same for the rest of the plugs, the back driver and passenger side are a PAIN and you may have trouble getting the spark plugs to start when putting them in. Take your time DO NOT force them or they will cross thread. which is BAD. So ease it in slowly and tighten it down by hand first.
It may take a couple different length extentions and maybe a swivle head but you will get it.
Old 03-23-2006, 12:10 PM   #3
DarkShadow's Avatar
Send a message via AIM to DarkShadow
Re: Spark Plugs
Bosch anything other than winshield wipers = no.
DarkShadow is offline   Reply With Quote
Old 03-23-2006, 12:33 PM   #4
Re: Spark Plugs
ive heard bad things about bosch and i had a bad experience with autolites... just use the stock motorcraft or motorcraft platinum (what i have now)
1999 3.8 V6 Electric Green Mustang
5 speed
Mods: MAC Dual Catback Exhaust, MAC Shorty Headers, CAI, Sequential Taillights, 03 17" Cobra Rims
My Garage
electricstang is offline   Reply With Quote
Old 03-23-2006, 04:45 PM   #5
Re: Spark Plugs
motorcraft all the way.
Old 03-23-2006, 07:01 PM   #6
megax29's Avatar
Re: Spark Plugs
I'm leaning towards the motorcraft platinum, what about the wires? Comments not enough to make me feel comfortable to do it myself. I have minimal tools. Got a ratchet and sockets thats bout it. I don't have extensions, much less swivel heads. Can I still do it? Does the plugs tightness really matter, cuz to measure 15lbs you need a special ratchet don't you, and I don't have that.
V6 Midnight Black
Old 03-23-2006, 09:54 PM   #7
Danger Dude's Avatar
Re: Spark Plugs
I would go with Motorcraft plugs and FMS (Ford MotorSport) plug wires. here is where I bought mine but any Ford dealership can get them
http://cgi.ebay.com/ebaymotors/Ford-...3096QQtcZphoto
Old 03-23-2006, 09:59 PM   #8
megax29's Avatar
Re: Spark Plugs
I'm gonna try asking for them at a Ford dealership to avoid the shipping. I need the 9mm?
V6 Midnight Black
Old 03-23-2006, 10:44 PM   #9
Re: Spark Plugs
You will spend more at a dealership with markup and tax. 9mm are fine!!!!
Old 03-24-2006, 08:11 AM   #10
Re: Spark Plugs
you will need some extensions and quite possibly a swivle head ~
Old 03-24-2006, 03:17 PM   #11
Re: Spark Plugs
are the motorcraft platinum plugs the best performance plug for v6 stangs? Where can i buy them online?
SonikBlueStang is offline   Reply With Quote
Old 03-24-2006, 03:34 PM   #12
Re: Spark Plugs
there are other wires that claim that are betterthan ford racing like nology magnecor and msd is thistrue
Old 03-24-2006, 03:52 PM   #13
Re: Spark Plugs
Just get what came in the car to start with. On a stock car, all you will do is cause problems by running other wires and plugs. Use what is meant to be used and don't worry about it.
Old 03-25-2006, 07:51 AM   #14
Re: Spark Plugs
There are some good aftermarket wires but FMS wires are very good.
Here is a fact if you believe all the hype manufacturers claim in the auto parts world then you should believe I am Elvis !!!! Now where are my jelly donuts!!!!
Spark plugs upton7 General Mustang Discussion 15 02-02-2010 02:00 PM
spark plugs v6stang04 Pre-2005 V6 Mustang 4 01-24-2010 06:22 PM
what spark plugs do i need fastfanatic 1996-2004 Mustang GT 6 09-14-2009 08:23 PM
Which spark plugs should I use??? koch_A_tyler 1996-2004 Mustang GT 5 03-18-2008 06:36 AM
Spark Plugs megax29 Pre-2005 V6 Mustang 20 10-09-2006 05:36 PM
06:41 AM
