gt take-offs - Mustang Evolution
Old 03-25-2006, 01:19 PM   #1
bluestang1724's Avatar
Exclamation gt take-offs
will gt take-offs decrease my torque?? i have heard so many different stories about how take offs will hurt my performance. can someone tell me if gt take-offs are even worth having. also, what if i replace the mufflers with flowmaster 40's will that make a difference? b/c i also heard that they will give the exhaust too much flow and result in even more torque loss or something like that. is that true???
bluestang1724 is offline   Reply With Quote
Old 03-25-2006, 01:30 PM   #2
Exclamation gt take offs
Old 03-25-2006, 02:52 PM   #3
Herbstang's Avatar
Re: gt take offs
you wouldn't even notice the small amount of torque you'll lose
Old 03-25-2006, 05:38 PM   #4
Re: gt take-offs
They decrease your low end torque, but they will give you a more high end. They will make your car faster. Replacing mufflers wont really do anything to your performance but it will make it sound a lot better.
neatofrito1618 is offline   Reply With Quote
Old 03-25-2006, 10:16 PM   #5
a00v6stang's Avatar
Re: gt take offs
yeah, you wont notice anything, how you gonna be putting it up?
It's all about how fast you get from point A to point B, now how you get there
a00v6stang is offline   Reply With Quote
Old 03-25-2006, 10:25 PM   #6
dark's Avatar
Send a message via AIM to dark Send a message via Yahoo to dark
Re: gt take offs
the miniscule loss is worth it in the long run
I don't own a mustang at the moment
dark is offline   Reply With Quote
Old 03-25-2006, 11:17 PM   #7
Re: gt take offs
i was thinkin of buying a pacesetter adapter or do you think i should go with straight pipes
Old 03-26-2006, 12:45 AM   #8
dark's Avatar
Re: gt take offs
pacesetter is the cheapy option. straight pipes on an odd firing engine won't do you much good either. i'd recommend a mac prochamber or an h or x pipe if you can afford one
Old 03-26-2006, 07:15 AM   #9
Tbird232ci's Avatar
Re: gt take offs
Its more like an H or X pipe wont do much on his engine, since the 3.8L has an even firing order.
As long as you keep your cats, you wont notice any loss in torque, the cats create more backpressure than the catback.
As long as you have the pacesetter welded up properly, it will work well.
Old 03-26-2006, 07:44 AM   #10
Re: gt take offs
If you are going to get an exhaust system, take-offs are the way to go. At no ppoint on the tachometer does my car sound ricey with them. Ive listened to some of these others guys cars with mac, flowmaster, etc and it sounds good at idle but when you get up into the high rpm, it sounds really "honda-ish" I have a 99 3.8 with bbk cold air intake and gt take offs and i swear sometimes there are days when you cant tell its not a v8. The air intake and the take offs together sound perfect. It has to be the best sound you can get out of a 6. Not to mention, take offs are so cheap.
blk99stang is offline   Reply With Quote
Old 03-26-2006, 09:13 PM   #11
Re: gt take offs
so i shouldnt get a pacesetter adapter. since 3.8's are an even firing engine i just need straight pipes
Old 03-27-2006, 03:03 PM   #12
Re: gt take-offs
they will not hurt your performance they will shave off a bit of time from your car. You lose back pressure so down low it may not feel QUITE as fast. You never really lose TQ you just move it up in the power band. I never noticed anything with the same size pipe in dual exhaust form with flowmasters. With stock GT mufflers they wont even flow as good as that so you really shouldnt notice anything.
Old 03-27-2006, 05:26 PM   #13
Re: gt take-offs
Originally Posted by lowflyn
Dude, how many threads about this are you gonna make?
i accidentially put in the wrong section. i ment to put it in the mustang tech section so i put it in the general discussion section by accident
Old 03-27-2006, 05:35 PM   #14
Re: gt take offs
do any of you reccomend putting on some mufflers like flowmaster 40's or should i just keep the stock ones on?
Old 03-28-2006, 10:54 AM   #15
Re: gt take-offs
see how you like the stock ones then go from there
Old 03-28-2006, 06:15 PM   #16
Re: gt take-offs
I would replace it with flowmaster 40's if your lookin for sound and not just performance.
take offs? wkndpaintballer Mustang Audio & Video 4 10-04-2007 02:49 PM
GT take-offs 97Stallion Mustang Parts for Sale and Wanted 5 06-24-2004 04:08 PM
GT Take Offs Mach_Mustang_R Pre-2005 V6 Mustang 36 02-24-2004 07:22 PM
09:33 AM
