how to install gt take offs - Mustang Evolution
Old 03-27-2006, 03:09 PM   #1
bluestang1724's Avatar
Exclamation how to install gt take offs
can someone give me step by step instructions on installing gt takr offs please give in detail.
bluestang1724 is offline   Reply With Quote
Old 03-27-2006, 03:19 PM   #2
Re: how to install gt take offs
You will need either a welder and a sawzall or take it to an exhaust shop. You will need to have your factory y-pipe cut, 2 new pipes bent and welded into place, then the rest of the exhaust hung into place, which will require making a few new hangers. So basically...carry it to an exhaust shop and pay them to put it on, you'll thank yourself later.
Old 03-27-2006, 04:06 PM   #3
there are two ways. Just cut and have a shop weld up the gt take offs. You will have to cut your pipe where they merge into a single pipe (after the cats) and then the shop will fab up a connection.
Or you can do it the "more better" way and buy an adaptor, aka a set of pipes that have a flange so you can bolt up the catback, so the shop can then weld on the adaptor an simply bolt your catback on. This is better due to you can bolt/unbolt any gt catback and gain easy acces to the tranny and what not. You can buy an adaptor for steeda, pacesetter, etc, or get a shop to make you one perhaps~ its just pipe with flanges that meet up with the GT take off's.
Old 03-27-2006, 06:32 PM   #4
how much will it cost to have the exhaust put on??
Old 03-27-2006, 08:09 PM   #5
depends on the shop, to just fab a connection i would think 100 or under would be acceptable~
Old 03-29-2006, 10:46 AM   #6
Send a message via AIM to tedness
well to give you a perspective my whole exhaust was $200 and that was with custom piping from them for everything
tedness is offline   Reply With Quote
Old 03-29-2006, 12:46 PM   #7
I would expect 125~ for gt take offs and another 50-80 installation~ depending. If you buy an adaptor pipe so you can bolt/unbolt the exhasut add on another 70~ ish
take offs? wkndpaintballer Mustang Audio & Video 4 10-04-2007 03:49 PM
GT take-offs 97Stallion Mustang Parts for Sale and Wanted 5 06-24-2004 05:08 PM
GT Take Offs Mach_Mustang_R Pre-2005 V6 Mustang 36 02-24-2004 08:22 PM
03:32 AM
