finishing some maintenance this week.... - Mustang Evolution
Old 03-29-2006, 09:37 AM   #1
Send a message via AIM to tedness
this is on my list so far of things to do...
- finished changing oil
- finished fuel filter and fuel system cleaning
left to do:
- change coolant
- change tranny fluid
- change differential fluid
- possibly change p/s fluid
in the next month:
- colder step copper spark plugs and new wires
- front brake upgrade to mach 1 calipers and brembo blanks with s/s lines
- serpentine belt w/ UDP and HB
you never realize how much you save doing this stuff yourself or with a friend until you've payed once for ford or superlube to do it. (not my car but my mom's)
tedness is offline   Reply With Quote
Old 03-29-2006, 11:47 AM   #2
Re: finishing some maintenance this week....
yea it adds up, some of that stuff i hate to do so I let whom ever do it as I watch. But generally I like to do that stuff myself if for no other reason than so I can say its done right
Old 03-30-2006, 07:57 AM   #3
in the next month:
Just curious what's the point of that?
-Denver
2002 Mineral Grey GT, 5-speed: MGW short throw, JLT CAI: SOLD
2002 Electric Green V6, Auto: SOLD
greenpony02 is offline   Reply With Quote
Old 03-30-2006, 08:40 PM   #4
Dom
Dom's Avatar
Send a message via AIM to Dom
I think I'm gonna change my fuel filter soon as a matter of fact. I have my belt, just need to get the attachment to release the tensioner.
Nothing like changing your own oil though. Nothing.
Old 03-30-2006, 08:55 PM   #5
Not sure myself, I always though the only reason to need to go colder was if you were going with Nitrous?
My car gets a complete overhaul in a month
Old 04-04-2006, 06:42 AM   #6
1 step colder was tested as getting better spark even on n/a cars. and copper is better than platinum if you don't care about lifespan
Old 04-04-2006, 10:45 AM   #7
What's the part # on those plugs?
-Denver
Old 04-10-2006, 10:06 PM   #8
Region: Iowa
Send a message via AIM to Horse Send a message via Yahoo to Horse
Dude, you just use a wrench to release the tension on the belt.
4.2L , CAI, BBK 65MM throttle body, 30lb injectors, SSM ported intakes, FLEX 1/2" spacer, RPM big valve heads, Comp roller rockers and cam, ASP-underdrive pulley, GT rear swaybar, & Quad Shocks, Full MM Coilover conversion, 17" Grey Torque Thrust wheels, FMS Aluminum driveshaft 8.8 rear w/ 3.73 gears, Tri-Ax Shorthrow shifter & SPEC stage II clutch w/ aluminum flywheel
Horse is offline   Reply With Quote
Old 04-10-2006, 11:57 PM   #9
Dom
Dom's Avatar
You need a T-55 to fit in the tensioner to reset the tensioner belt wear thing.
I ended up just just lifting on on the bottom bolt/pulley with a wrench and taking the belt off.
Maintenance?? Ken The Bar 9 10-04-2009 08:53 AM
Tranny Maintenance LSUstang Pre-2005 V6 Mustang 0 06-26-2008 11:15 AM
Finishing up 3.8 mods 98GreenStallion Pre-2005 V6 Mustang 5 02-17-2005 06:49 AM
General Maintenance lowflyn Pre-2005 V6 Mustang 69 01-11-2005 07:15 PM
Maintenance lowflyn Pre-2005 V6 Mustang 7 11-10-2004 06:28 PM
08:41 PM
