power steering pump replacement - Mustang Evolution
Old 02-24-2010, 08:22 PM   #1
A.K.A. Baby-D!
ok guys trying to change my power steering pump. we got the old pump out, but the new pump doesn't come with a reservoir... my question is how do we remove the reservoir from the old pump? if anyone has dealt with this before please give some advice...
and its an 04 3.9L V6
Current:
1989 GT--the project
Previous:
2004 V6--my first pony
1988 GT--July 2010 MOTM
Old 03-05-2010, 07:18 PM   #2
Region: Iowa
Send a message via AIM to Horse Send a message via Yahoo to Horse
Re: power steering pump replacement
There are some clips on the back side of the pump. Once you have the pump out there should be some retainers that hold the reservoir on. Pop those loose and reattach to your new pump. At least that's how most fords do it. I've not had the pump off my mustang to look at it.
4.2L , CAI, BBK 65MM throttle body, 30lb injectors, SSM ported intakes, FLEX 1/2" spacer, RPM big valve heads, Comp roller rockers and cam, ASP-underdrive pulley, GT rear swaybar, & Quad Shocks, Full MM Coilover conversion, 17" Grey Torque Thrust wheels, FMS Aluminum driveshaft 8.8 rear w/ 3.73 gears, Tri-Ax Shorthrow shifter & SPEC stage II clutch w/ aluminum flywheel
Horse is offline   Reply With Quote
Which Power Steering Pump? Rainman64 Classic Mustangs 1 02-02-2010 07:39 PM
Winey power steering pump KC5.0 1979-1995 Mustang GT 3 03-28-2009 09:38 AM
Power Steering Pump floridamba Pre-2005 V6 Mustang 4 04-09-2007 05:34 AM
Power Steering Pump Removal Help Justin 1979-1995 Mustang GT 7 03-12-2007 08:24 PM
Power Steering Pump Pulley Kiljosh Mustang Parts for Sale and Wanted 0 06-04-2005 10:57 PM
11:58 PM
