Manual for v6 - Mustang Evolution
Old 02-25-2010, 05:39 AM   #1
Manual for v6
I was wondering if i should stick with the auto or go with a manual trans? I am planning on doing the one of the power paks and maybe eventually a turbo, headers and exhaust. I was wondering which standard trans will bolt up to a 2001 v6 if i go that way.
xcxm049 is offline   Reply With Quote
Old 02-25-2010, 07:10 AM   #2
Re: Manual for v6
well its probably best to sell your car and buy another one to do this, but if you plan to rip out and rebuild the motor its not going to make it to much worse to put in a manual trans.
If its a 99-04 then a T-5 if what you want.
Old 02-25-2010, 10:45 AM   #3
upton7's Avatar
Re: Manual for v6
naaahhhh he want a tko lol
Old 02-25-2010, 12:17 PM   #4
big show 98's Avatar
Re: Manual for v6
+1
big show 98 is offline   Reply With Quote
Old 02-25-2010, 01:52 PM   #5
Re: Manual for v6
Well i am not selling the car, but thanks for the info. The t-5 will the bell housing for it bolt straight up to the motor?
Old 02-25-2010, 05:10 PM   #6
Re: Manual for v6
It will bolt right up. Make sure & get one for a 99-04 3.8.
Old 02-26-2010, 09:08 AM   #7
Re: Manual for v6
Thanks for the help.
Old 02-26-2010, 09:12 AM   #8
Re: Manual for v6
mustangs from 94-04 have had a T-5 in them from ford. The issue is some have a digital read tail shaft for MPH vs gear driven (swapped to digital in 99) so FYI on that, you can swap tail shafts if need be but just look for one thats digital.
Old 02-26-2010, 09:50 AM   #9
Re: Manual for v6
Well, I agree that maybe you should sell that one and buy a manual. Now, if you insist on tearing down the one you have then I would still go with a manual. I have never owned a automatic. I enjoy having total control over the car.
SuperDave2010 is offline   Reply With Quote
Old 02-26-2010, 10:37 PM   #10
Region: Iowa
Send a message via AIM to Horse Send a message via Yahoo to Horse
Re: Manual for v6
Manual trans FTW!
4.2L , CAI, BBK 65MM throttle body, 30lb injectors, SSM ported intakes, FLEX 1/2" spacer, RPM big valve heads, Comp roller rockers and cam, ASP-underdrive pulley, GT rear swaybar, & Quad Shocks, Full MM Coilover conversion, 17" Grey Torque Thrust wheels, FMS Aluminum driveshaft 8.8 rear w/ 3.73 gears, Tri-Ax Shorthrow shifter & SPEC stage II clutch w/ aluminum flywheel
Horse is offline   Reply With Quote
Auto vs Manual Justin 1979-1995 Mustang GT 5 05-10-2006 10:15 PM
Just bought an 06 V6 Manual justin00stang Pre-2005 V6 Mustang 21 03-12-2006 05:14 PM
3.8 auto vs manual megax29 Pre-2005 V6 Mustang 14 10-24-2004 10:43 AM
auto or manual? oaktonarcher The Bar 31 06-07-2004 12:39 PM
06:08 PM
