Where to get a 4.2 block - Mustang Evolution
Old 02-25-2010, 10:39 PM   #1
Zebs5408's Avatar
I need a 4.2 block w/ pistons and crank out of a v6 f150 asap, anyone know a spot?
04' mustang 3.9 40th Anniversary Edition- (V2 Vortech Supercharger, 38# injectors, 3.73 gears w/ T-lok, Predator Diablo, Mac cold air intake, Port & polished upper AND lower intake manifold, Mac Long Tube Headers, Mac o/r H pipe, flowmasters, 2.5 flowmaster tips)
03' Mustang GT (20" Cobra R's, 40 series Flowmasters)
Zebs5408 is offline   Reply With Quote
Old 02-25-2010, 10:50 PM   #2
Zim
You want to **** me?
Zim's Avatar
Re: Where to get a 4.2 block
junk yard?
search craigslist for a wrecked f150 thats being parted out?
Those are my 2 ideas.
I like toys
Old 02-26-2010, 09:52 AM   #3
upton7's Avatar
Junkyard.
Old 02-26-2010, 09:58 AM   #4
Try pull-a-part if there's one near you. Or do as the posters above me had mentioned.
19Delta is offline   Reply With Quote
Old 02-26-2010, 02:30 PM   #5
blackonblack's Avatar
haha this 1 night project has turned into something terrible!lol
i say junkyard too, def a f150 layin around somewhere. good luck brosky
2004 3.9L v6
Black on black on black
MAC Cold Air Intake, 4.10 gears + T-Lok, SCT Tuner, dual H piped flowmaster super 40's
blackonblack is offline   Reply With Quote
Old 02-26-2010, 07:28 PM   #6
Region: Iowa
Send a message via AIM to Horse Send a message via Yahoo to Horse
I got mine from a junkyard off e-bay. Drove to Oklahoma to get it 'cause freight was going to cost me more than the motor did.
4.2L , CAI, BBK 65MM throttle body, 30lb injectors, SSM ported intakes, FLEX 1/2" spacer, RPM big valve heads, Comp roller rockers and cam, ASP-underdrive pulley, GT rear swaybar, & Quad Shocks, Full MM Coilover conversion, 17" Grey Torque Thrust wheels, FMS Aluminum driveshaft 8.8 rear w/ 3.73 gears, Tri-Ax Shorthrow shifter & SPEC stage II clutch w/ aluminum flywheel
Horse is offline   Reply With Quote
Old 02-26-2010, 08:08 PM   #7
Yah a good ol' junkyard find will do the job. Just make sure the truck body is the reason it's there and not a cracked block. That'll piss a man off real good.
Old 02-27-2010, 12:23 AM   #8
Zim
Zim's Avatar
now that i think about it.... if you're doing a motor swap, why not drop a 289 or 302 in there?
maybe you'll even get lucky and find an old f250 with a 351!
I like toys
Old 02-27-2010, 01:30 AM   #9
upton7's Avatar
If you decide on a 4.6 sohc I know a guy with internals and heads and more
Old 02-27-2010, 12:21 PM   #10
that'd be *****in!
Old 02-27-2010, 01:46 PM   #11
There's a 4.6 on craigslist in my area with the ECU for 650, if that's what you're wanting. Also, the same guy has a T45 for 200.
5.0 on a 4.6 block. DaDant! 1996-2004 Mustang GT 2 02-06-2009 08:35 PM
302 Block Help ejl22boo 1979-1995 Mustang GT 2 02-01-2009 07:50 AM
4.6L Block hawks05 Mustang Parts for Sale and Wanted 1 03-30-2005 01:16 AM
4.2 Block n8r Pre-2005 V6 Mustang 5 06-12-2004 10:10 AM
91 Block the same as 94+? Brent Pre-2005 V6 Mustang 10 11-07-2003 08:13 AM
06:16 PM
