brake switch out - Mustang Evolution
Old 04-02-2006, 07:42 PM   #1
Send a message via AIM to whitev6stang03 Send a message via MSN to whitev6stang03 Send a message via Yahoo to whitev6stang03
brake switch out
would a 2001 3.8 mustang front and rear brakes fit on a 1997 3.8 mustang?
whitev6stang03 is offline   Reply With Quote
Old 04-03-2006, 11:23 AM   #2
Re: brake switch out
I believe they're all the same...
Old 04-03-2006, 12:53 PM   #3
they will bolt up BUT the front 99 calipers fitting on a 97 mustang may cause a SLIGHT issue when you try to fit the caliper bolt in, this may or may not happen. The fix is to simply grind the knuckle down a bit so the caliper can slide on down a bit, its only like 2/10ths of an inch off~ really easy fix.
Old 04-03-2006, 06:50 PM   #4
oh thats great, my 1997 mustang's brakes are not the best, and plus these 2001 brakes look nice painted red
thanks
Old 04-03-2006, 06:58 PM   #5
The 99+ Brake calipers are 2 piston compared to your stock ones which are 1 piston Much better,
Old 04-05-2006, 06:53 PM   #6
i have another questions, since the calipers are taken off already, how can i push the pistons down? and will i run into any minor problems installing them? do they just bolt on and bingo thats it?
Old 04-05-2006, 06:57 PM   #7
If I recall WhiteStang99 did it by hand... and you should not run into any other problems other than what SpectorV mentioned
Old 04-05-2006, 07:00 PM   #8
awesome then i should have none
Old 04-05-2006, 09:31 PM   #9
If you can't get it by hand, just get a cheap c clamp from any hardware store. Always handy to keep around. by god
Old 04-06-2006, 09:26 AM   #10
97Stallion's Avatar
Yup, i did this myself and it makes a world of a difference. You will definately need to sand down the edges and it's more like .070" from each end. They will slide in just fine then.
Living one day at a time!
ignition switch upton7 1996-2004 Mustang GT 6 01-17-2010 10:51 PM
94-98 foglight switch Smokedya95stang Mustang Parts for Sale and Wanted 1 09-22-2006 09:15 AM
switch help! jimmy_beaner The Bar 10 11-22-2004 11:51 AM
03:53 PM
