high pitched noise - Mustang Evolution
Old 04-03-2006, 11:30 AM   #1
meteorachick's Avatar
high pitched noise
i determined that it is not from the engine, but rather from the wheels but i can't pinpoint it, it almost sounds like a high pitched "wavy" kinda noise as the car is moving
any idea of what i should look for? or what it could be?
Old 04-03-2006, 11:32 AM   #2
Re: high pitched noise
How fast do you have to be going until you hear the noise? Can you roll it in Neutral and hear it?
Old 04-03-2006, 11:33 AM   #3
didn't try that, but i will in a few mins
Old 04-03-2006, 11:33 AM   #4
Yeh, I get slight gear whine around 45-50...at least I used to when I could hear my car.
Old 04-03-2006, 12:52 PM   #5
does it speed up/slow down try pushing the brakes when its doing it to see if it goes away.
Old 04-03-2006, 02:36 PM   #6
bbunt302's Avatar
If it seems to do it at a certain speed, regardless of engine rpm (i.e. in neutral or any other gear), then it could be a front wheel bearing. This will get noticeably worse in time.
If it does it more in a certain gear (usually OD at a decent speed), then it is more likely gear whine. You'll probably always have at least a little bit of gear whine, it's just a matter of how loud it is and whether or not it is noticeable.
Try to figure out if it's coming from the front or the rear.
Scary stuff.
Old 04-03-2006, 02:58 PM   #7
does it sound more like "HIGH PITCHED NOISE SEMI WAVY" or more like "HIGH PITCHED NOISE NORMAL WAVY"
Old 04-03-2006, 03:26 PM   #8
I_luv_HP&trq's Avatar
Send a message via AIM to I_luv_HP&trq Send a message via MSN to I_luv_HP&trq
Find a smooth open road and swerve your car right and left like a drunk driver. If you hear the whine then it's most likely a ball bearing issue.
99 Cobra: flowmasters, 18x9.5 cobra R's, soon to be tuned and geared. daily driver
99 V6:in avatar, Mac Cai, true duals/flowmaster 40's ,UDP, custom tuned, bullitt suspension 18" wheels...taken by mother nature
I_luv_HP&trq is offline   Reply With Quote
sqwheeling noise? Dude87 General Car Discussion 4 10-03-2008 01:11 PM
Tranny noise Foxone Pre-2005 V6 Mustang 3 08-27-2008 10:31 PM
Clicking Noise kind of Squeeky Noise... braumab 2005-2010 Mustang GT 23 06-29-2008 11:24 PM
Engine Noise??? Special K 1996-2004 Mustang GT 14 09-07-2006 11:59 PM
Weird noise electricstang Pre-2005 V6 Mustang 17 06-20-2006 06:29 AM
12:27 PM
