P/p Intakes - Mustang Evolution
Old 04-03-2006, 08:53 PM   #1
P/p Intakes
Just wondering a few things about these. I'm looking to do something small to the engine this summer, but something kinda noticable. Ok..with p/p intakes (upper and lower), will I need to have a tune done? Also, I know it's not but around 10 hp tops, but where is the gain in the power band? Just kinda curious.
Old 04-03-2006, 09:02 PM   #2
Re: P/p Intakes
No you will not need a tune and the power gain is up top I would think. The tune comes in with a cam...
Old 04-03-2006, 10:13 PM   #3
Re: P/p Intakes
I would say get a 75 shot.
Old 04-03-2006, 10:17 PM   #4
Re: P/p Intakes
Actually I believe the 99+ would respond well to a ported upper and lower since their Heads already flow well.
Old 04-04-2006, 12:34 PM   #5
Re: P/p Intakes
Hm...the reason I don't want nitrous is I'd be wayy too tempted to use it too much. And it would get expensive to drive the hour to the nearest fill station around here.
Old 04-04-2006, 01:56 PM   #6
Re: P/p Intakes
I would do the ported intakes Then save up for some nice heads for a mod for the summer after this one. Make it a nice slow project build up?
Old 04-04-2006, 02:00 PM   #7
I_luv_HP&trq's Avatar
Send a message via AIM to I_luv_HP&trq Send a message via MSN to I_luv_HP&trq
Re: P/p Intakes
I'm in the process right now of porting my lower intake. The ports and runners are incredibly tiny. The uppers aren't so bad but yea the lower intake is very restrictive. It's not the funnest process but then again if you have the proper tools unlike me, then it will go by a lot smoother. It's almost free hp depending on what you spend on tools.
99 Cobra: flowmasters, 18x9.5 cobra R's, soon to be tuned and geared. daily driver
99 V6:in avatar, Mac Cai, true duals/flowmaster 40's ,UDP, custom tuned, bullitt suspension 18" wheels...taken by mother nature
I_luv_HP&trq is offline   Reply With Quote
Old 04-04-2006, 02:29 PM   #8
Re: P/p Intakes
Ha...well I'm just gonna buy from one of the sponsors who know what they're doing.
Old 04-06-2006, 09:13 AM   #9
97Stallion's Avatar
Re: P/p Intakes
As well as the 99-04 intakes flow, there is still ALOT of material to remove. You might be surprised to the amount of air flow you can pick up by porting them.
Living one day at a time!
Old 04-06-2006, 06:43 PM   #10
slvr2000stang's Avatar
Re: P/p Intakes
Very true.
Custom Delk motor now DOA
2003 SVT Lightning #1059 of 4270
2000 Vert 4R70W
Only buy from vendors that test and stand behind their products
slvr2000stang is offline   Reply With Quote
Old 04-06-2006, 08:49 PM   #11
jimmy_beaner's Avatar
Region: Iowa
Re: P/p Intakes
I have a ported upper intake here... of course I did the work, but yeah, there is a lot of material to be removed.... A LOT. I still have a little bit of finishing work to do on it.
Old 04-10-2006, 09:36 PM   #12
RGR
Send a message via AIM to RGR
Re: P/p Intakes
Very true. I did the first set ever in April, 1999, had a guy yank his and
sned them to me from Texas and he dynoed it, got +13 RWHP and + 16 RWTQ.
The torque was pretty much from 2500 RPM and up, and added 13 HP at the
peak. The torque down low comes from smoother runners and laminar flow.
Hog out those short runners to the gaskets, and just square up the long
runners. I only marginally enlarged the short runners on the one above, and
it still gained 13 HP. I suggest a cam and intake porting all the time to those
with limited funds, the heads flow really well for stock. Better than almost all
small block Ford heads ever cast, and if you consider velocity, they flow better
than even 4V Cleveland heads. Lots better. Almost the same flow with ports
that are 1/2 the size of a 4V Cleveland. Pretty good for 30+ years of technology.
Originally Posted by Flex:
You are the true cam master dude...
RGR is offline   Reply With Quote
Old 04-11-2006, 08:34 AM   #13
Dom
Dom's Avatar
Send a message via AIM to Dom
Re: P/p Intakes
Stuff like that makes me want to do a split port swap.
Old 04-11-2006, 07:23 PM   #14
Re: P/p Intakes
Have you considered a 3/8" spacer too that's ported? I got a spacer on mine but I don't know if I got the $$$ to do PP upper and lower.
machoman013 is offline   Reply With Quote
Old 04-14-2006, 10:10 AM   #15
Re: P/p Intakes
if you have a spacer already, would a generic shop be capable of just porting the spacer as well if you bought le't ssay upper and lower p/p's from rpm?
5.0 intakes bobby88 1979-1995 Mustang GT 2 02-04-2008 04:26 PM
Intakes for sale dragonlouie Mustang Parts for Sale and Wanted 0 08-22-2007 05:53 AM
v6 intakes speedyhank Pre-2005 V6 Mustang 13 08-17-2004 08:02 PM
95 Intakes njstang97 Pre-2005 V6 Mustang 3 06-09-2004 06:46 PM
08:01 PM
