V6 Steering - Mustang Evolution
Old 02-28-2010, 09:13 AM   #1
HEC
V6 Steering
I bought a 2000 V6 for my daughter that has Cobra rims and tires installed on it and the steering is a fight. The car tries to "track" down the road trying to follow every valley an uneven surface we drive across. Is the stock rack and pinion capable of handling these tires?
HEC is offline   Reply With Quote
Old 02-28-2010, 12:33 PM   #2
upton7's Avatar
Re: V6 Steering
is it really really bad?
Old 02-28-2010, 01:31 PM   #3
HEC
Re: V6 Steering
It is bad and it is tiring to drive, not enjoyable at all, also very tough on a beginner driver.
Old 02-28-2010, 02:56 PM   #4
upton7's Avatar
Re: V6 Steering
Mustang steering isn't anything like newer cars now like cadillac lexus and what not I don't think it would be the wheels that are put on causing it but you might need an alignment job.
Old 02-28-2010, 03:02 PM   #5
blackonblack's Avatar
Re: V6 Steering
the rims were already on when you bought?
2004 3.9L v6
Black on black on black
MAC Cold Air Intake, 4.10 gears + T-Lok, SCT Tuner, dual H piped flowmaster super 40's
blackonblack is offline   Reply With Quote
Old 03-01-2010, 07:14 AM   #6
Re: V6 Steering
I had the basic same setup on my 01 v6 with no issues. Alignment and tires worn bad etc can cause "tracking". I would check the alignment first to see how bad off it is. Some areas have worse roads that cause these issues~
Old 03-01-2010, 11:46 AM   #7
Re: V6 Steering
Yah sounds like an alignment problem. Check your tires, see if they are wearing unevenly or cupping...that will contribute to tracking as well.
Old 03-01-2010, 01:51 PM   #8
Region: Iowa
Send a message via AIM to Horse Send a message via Yahoo to Horse
Re: V6 Steering
Wider tires will cause that to happen, but It shouldn't wear you out to drive it. If it's really that bad I'd say you either have worn front end parts, or badly set toe.
4.2L , CAI, BBK 65MM throttle body, 30lb injectors, SSM ported intakes, FLEX 1/2" spacer, RPM big valve heads, Comp roller rockers and cam, ASP-underdrive pulley, GT rear swaybar, & Quad Shocks, Full MM Coilover conversion, 17" Grey Torque Thrust wheels, FMS Aluminum driveshaft 8.8 rear w/ 3.73 gears, Tri-Ax Shorthrow shifter & SPEC stage II clutch w/ aluminum flywheel
Horse is offline   Reply With Quote
Power Steering? NeedSomeMods Pre-2005 V6 Mustang 4 08-30-2009 01:23 AM
Steering problem kercolla New Member Introductions & Greetings 2 08-21-2009 04:35 PM
steering wheel please help?!?! rello Pre-2005 V6 Mustang 14 08-01-2009 06:07 PM
PLEASE SOMEBODY HELP!! (Steering Rack) savedbygrace 1979-1995 Mustang GT 6 10-11-2008 11:22 AM
Steering squeaks NorwegianMustang Pre-2005 V6 Mustang 1 07-31-2003 11:12 PM
10:21 PM
