Burning Rubber - Mustang Evolution
Old 04-04-2006, 01:58 PM   #1
megax29's Avatar
Send a message via AIM to megax29 Send a message via Yahoo to megax29
Burning Rubber
Whenever I race and I feel confident enough to burn rubber I power launch, release the break and slam the gas all the way. I usually stay at the line spinning my tire while rpms get to about 4k then it shifts into 2nd gear. My question is why does it shift into 2nd and not redline? Would a tuner help change this, maybe? I feel like it messes me up so much. Sometimes while I'm spinning the car advances a bit forward then shifts into 2nd, all the while the other car is moving forward, only then do I have a chance at catching up. If it redlined I think it would well be better since I'm missing out on 1.5k rpms.
V6 Midnight Black
CAI w/ K&N Filter, Tokico Complete Suspension kit, Single Flowmaster w/ turndown, GT rear sway bar.
megax29 is offline   Reply With Quote
Old 04-04-2006, 02:02 PM   #2
Re: Burning Rubber
In that 1.5k rpms...you will be doing nothing but spinning. Spinning will not help you win a race. Spinning is a good way to help yourself lose races. The other guy is just pulling on you because he is not spinning.
And, your car is shifting because that is the RPM that the computer knows to shift at. It doesn't care if you are moving at 1 mph or 100 mph....when it reaches the shift point, it shifts. A tuner can change your shift points, but as long as you are spinning, you will not be doing anything better. The shift is actually helping you as it will kill your spin and let the power move you forward.
Trust me...spin = sucky race results....and I know a lot about spinning at launch. I lost to a GT with 140 hp less than me because I could not stop spinning through 1st, 2nd, and 1/2 of 3rd....
Old 04-04-2006, 02:29 PM   #3
Re: Burning Rubber
Yeh, don't launch like that, your goal is to not spin, or spin minimally.
Old 04-04-2006, 03:01 PM   #4
Re: Burning Rubber
i found that funny.
Any way dude get a t-lok ever since i put one in it made a world of difference get some 4.10 gears while you at it they wake the car up soooo nicely.
Old 04-04-2006, 05:55 PM   #5
Re: Burning Rubber
A Traction lok and 17" rims do wonder for traction on a stock V6 Mustang... its almost impossible to spin the tires on launch
Old 04-04-2006, 06:02 PM   #6
jimmy_beaner's Avatar
Region: Iowa
Re: Burning Rubber
I read that.... "I spin through first gear" going, omg, no way, not unless you have sand or water on the road... and then I remembered, doh, I had a GT rear, if I just punched it at a light, they'd cut loose a bit, but within 3 seconds, first gear would be cooking... never shifted to second unless sand or water was on the road, and then I could peel out until 3rd.
Old 04-05-2006, 09:10 AM   #7
Herbstang's Avatar
Re: Burning Rubber
Save your tires & read this http://www.mustangevolution.com/foru...race-5596.html
DVD Burning Help Seph The Bar 0 03-04-2007 07:18 PM
Having a problem burning DVD Danger Dude The Bar 3 06-01-2005 07:00 PM
Why Is My Car Burning So Much Gas? NateTrain Pre-2005 V6 Mustang 30 05-24-2005 02:30 PM
dvd burning STEVE The Bar 13 10-28-2004 08:21 PM
03:39 AM
