4.2L mod question - Mustang Evolution
Old 04-04-2006, 10:44 PM   #1
4.2L mod question
If ever in the event my 3.8 blows, is it possible to still use my basic bolt ons like the UDP, (assuming exhaust as well), intake spacer, and cai if I swapped with a 99+ f150 when I'm an 03 3.8L? I know it'll take other modification and needs for parts to, but I wouldn't want my other mods to go to waste.
machoman013 is offline   Reply With Quote
Old 04-05-2006, 01:35 AM   #2
Kiljosh's Avatar
Re: 4.2L mod question
The 4.2l is in essence the 3.8l but with a different crankshaft. When you swap it over youll put all your mustang stuff back on to it. It will all fit as its nearly the exact same engine from the outside.
Old 04-05-2006, 02:33 AM   #3
Depends on the year of your Mustang
Old 04-05-2006, 02:52 AM   #4
Yes you can use most of it, the upper half is pretty much the same its the internals that differ.
neatofrito1618 is offline   Reply With Quote
Old 04-05-2006, 12:22 PM   #5
good to know, i have a 2003 mustang. thanks guys.
Old 04-06-2006, 09:07 AM   #6
97Stallion's Avatar
Ok here's the dealio. If you have a 94-98 V6, you can directly swap over UDP if you use a rotating assembly from a 97-98 4.2. You still need to use the 4.2 balancer, but the pulley can still be the UD one. If you buy a later rotation assembly, you'll need to buy a late 01 UDP. You'll also need to buy a late 01 oil pan and pick-up tube, because of clearence issues. If you have 99-early 01 V6, you need to buy a 01+ UDP, you might be able to get away with using your stock oilpan/pick-up tube, but that's your call not mine. If you have a late 01-04, you can swap over everything literally since both motors are internally balanced. This should clear up some questions.
Living one day at a time!
Mod question/suggestions - '02 GT ChrissyStang02 1996-2004 Mustang GT 12 08-11-2007 07:30 AM
351 mod question 351mod_stang 1979-1995 Mustang GT 9 08-15-2006 07:08 PM
first mod? powerhungry966 1979-1995 Mustang GT 9 06-10-2006 11:06 AM
Question about the new CryO2 Mod... PerformanceRed2000_V6 Pre-2005 V6 Mustang 6 04-29-2004 01:05 PM
What should my next Mod be? tippie2000 Pre-2005 V6 Mustang 24 04-07-2004 03:49 PM
01:25 AM
