Struts and Shocks - Mustang Evolution
Old 03-02-2010, 08:16 PM   #1
Struts and Shocks
What type of strut and shock is a good one for just a daily driver? i am lowering my stang and don't know which brand to buy, Any help is appreciated. Looking at tokico, but don't know much about them.
xcxm049 is offline   Reply With Quote
Old 03-02-2010, 08:27 PM   #2
Re: Struts and Shocks
What springs are you lowering with? Tokico is a good brand. Put those on my V6 when I lowered it at 30k, they had to be changed at 130k so I figure that's not bad for a car lowered on cut C-springs.
Old 03-03-2010, 04:51 AM   #3
I am putting some ebay springs on it, they are suppost to drop it about two inches.
Old 03-03-2010, 07:18 AM   #4
its its just a stock setup you are looking for look for some stock shocks/struts and see how the price is~ check with Tousley Ford Parts Depot
Old 03-03-2010, 09:51 AM   #5
well not really stock. eventually i am going to turbo or supercharge. so i want something now thats going to look good but handle the power later on
Old 03-03-2010, 10:03 AM   #6
upton7's Avatar
I have tokico and can't tell a difference over stock.
Old 03-03-2010, 10:16 AM   #7
Region: Iowa
Which type of Tokico's are you running?
NQSperformance
Vendor for:
American Muscle - Maximum Motorsports - Stack Racing - Koni - Tokico - H&R - Eibach - Hawk - Powerslot
John@NQS is offline   Reply With Quote
Old 03-03-2010, 10:18 AM   #8
upton7's Avatar
d spec
Old 03-03-2010, 08:24 PM   #9
so what would be something good, to replace the stock ones with cause they are shot. Plus i am going to have them out to change the springs anyways so might as well change them all at once. Also which caster camber plates are good. I have seen three and four bolt, what are the difference in the two besides one has four bolts?
Old 03-03-2010, 09:07 PM   #10
Region: Iowa
Maximum Motorsports makes a high quality caster-camber component which also comes with a limited lifetime warranty. Koni (which are on sale right now), Bilsteins, and Tokico are good shocks.
NQSperformance
Vendor for:
Old 03-03-2010, 09:14 PM   #11
Region: Iowa
d spec
Interesting. So you didn't see any difference from the soft to firm settings? I've put these on s197 cars and could tell quite a bit of difference. The softest was slightly softer than stock and the firm was quite a bit firmer than stock (although not as stiff as the Koni Yellows on full Firm). I have not had a chance to install/ride on a SN95 car with the D-specs though.
NQSperformance
Vendor for:
Old 03-05-2010, 12:59 PM   #12
97Stallion's Avatar
I'm not sure of the year of your car, but if it's somewhat old (pre 05), you can get some tokicos from the ford deal, the 01 Bullitt used tokicos as OEM parts. They are black, but tokicos none the less. Just stating if money is an issue they run about (200-250 for the set). Also, I doubt they'll fit newer models. If you have a newer model and money is an issue tokicos are still the best part for the cheapest price you can get. They come in blue which are non-adjustable and white which are adjustable. If money is not an issue I would highly recommend Yellow Konis or Bilstein.
Living one day at a time!
SHOCKS/STRUTS Gt.Vert 1996-2004 Mustang GT 16 04-28-2010 08:15 PM
shocks/struts Sublime782 Pre-2005 V6 Mustang 15 05-15-2007 01:06 PM
shocks and struts all8280bcc 1996-2004 Mustang GT 8 03-01-2007 12:49 PM
Shocks Struts megax29 Pre-2005 V6 Mustang 11 07-12-2006 09:34 PM
Shocks..struts Exit_In_Red Pre-2005 V6 Mustang 6 12-01-2004 10:33 PM
11:26 PM
