Sat all Winter - Mustang Evolution
Old 04-08-2006, 05:20 PM   #1
Sat all Winter
I have a '99 V6 Stang that I let sit all winter. I started it a couple of times just to make sure it would start, but the last time I think I let it set too long.
So. I tried to start it and it crank till it drained the battery. So I jumped it with my van, still no success.
So I got some dry gas, tried that - still no success. So today, I changed the fuel filter - which alot claim is really easy, which it is after you have went to the store 3 times to buy the tool to remove the filter, then a lift and jacks, and then another trip after I snapped the tool, and needed to pickup some other tools.
After I changed the fuel filter, I put the van back on and let it charge the stang for awhile. I tried to start the stang several times, at one time, it almost turned over, but never did.
So, now I am not sure what to do and I am looking for suggestions from you all.
Do I change the plugs?
Car as 123,000 miles on it - had a tune up about 80k.
Thanks.
Keith
kmurrey is offline   Reply With Quote
Old 04-08-2006, 05:44 PM   #2
powerhungry966's Avatar
Send a message via AIM to powerhungry966
Re: Sat all Winter
maybe alternator could be bad.. i beleive u can trade ur old alternator in for a new one for like 40 dollars off? somthing like that.. IF THATS the case that is... if not check plugs/wires.. make sure they're not F*cked
1989 coupe 5.0 yeessur.
"Shake n bake"
powerhungry966 is offline   Reply With Quote
Old 04-09-2006, 03:32 AM   #3
97Stallion's Avatar
Re: Sat all Winter
I would put my money on the wires and plugs. Something there has to be the problem. Check the resistance of your wires and your plugs. If there is little or none, then it could be a fuel problem which would then either be your injectors or FPR or your pump. Lets hope it's not your pump.
Living one day at a time!
Old 04-09-2006, 09:45 AM   #4
Dom
Dom's Avatar
Send a message via AIM to Dom
Re: Sat all Winter
And if it is, I hope you didn't fill your tank up before you parked it.
Old 04-09-2006, 08:46 PM   #5
Re: Sat all Winter
It was about 1/2 full....
So you think I should just change the plugs first or just the wires first?
Old 04-10-2006, 11:41 AM   #6
Kiljosh's Avatar
Re: Sat all Winter
Id get a siphon pump and get all the old gas out and replace it with fresh stuff. Pour some drygas in as well. After that try to start it again. See if it may be bad gas.
If you still got nothing look at the plugs and wires...
Old 04-10-2006, 08:43 PM   #7
Re: Sat all Winter
Well - had some better luck today - it was pretty nice here - in the upper 60's so it dried up something.
The car started to turn over but the battery died on the second crank. So now I have the charger on, hopefully tomorrow it will startup.
If not - I will probably drain the tank, add some new, and try that - then change plugs, etc. if I have to.
Thanks for all the advice guys - I will let you know what happens.
Old 04-11-2006, 09:00 AM   #8
Dom
Dom's Avatar
Re: Sat all Winter
Maybe you should go invest into a new battery. It might not be taking charge anymore.
Old 04-11-2006, 08:43 PM   #9
Re: Sat all Winter
We'll - it's taking a charge just fine.
Problem is that it start to turn over, to the point where the whole car starts to shake, but it just won't kick over.
So now I am back to square one. I may try removing the gas - about 1/2 tank, and trying some new gas.
Hammond LA car show Sat night rickf73 Pictures and Videos 6 06-15-2010 06:28 PM
Wildhorses show sat nov 21st 2009 wildhorsesprez Regional Mustang Discussion 4 11-25-2009 02:27 PM
Laurens County, SC Car Show Sat 7/7/07 KrazyPony Pictures and Videos 2 07-09-2007 03:14 PM
T/S/D night rally Sat 9/24 starting in Mount Kisco NY TurboMike Regional Mustang Discussion 0 09-15-2005 09:04 PM
RE: California Speedway This Sat Joshness The Bar 4 07-15-2003 11:03 AM
04:39 AM
