cigarette lighter trouble - Mustang Evolution
Old 03-03-2010, 04:58 PM   #1
I could use a little advice on how to fix my cigarette lighter on my 2001 mustang. my cigarette lighter next to my gear shift has never worked since i bought the car, so i checked out the fuses ans sure enough, the one for the lighter was blown. so i replaced it, but when i went to use the lighter, it blew the fuse again. so obviously the problem is that there is a short somewhere or something. What should i do? is this a common issue?
w_nixon is offline   Reply With Quote
Old 03-03-2010, 06:18 PM   #2
Re: cigarette lighter trouble
Never had an issue in my 02, but the cobra has been having the same issues. I just don't use the one by the shifter and only use the one in the armrest. Kinda annoying at times but it doesn't bother me.
Old 03-04-2010, 05:40 AM   #3
wiarumas's Avatar
i think the universe is trying to tell you something (dont smoke) haha
as far as im aware, its not a common issue. might want to just check the wires and see if there is anything fishy going on in there. maybe check the voltage.
Old 03-04-2010, 08:38 AM   #4
Yah check the wiring for sure. If you replaced a fuse once and it blew again, then something else is wrong. Sometimes manufacturers group circuits into one fuse, so if you had other problems (fog lights, cruise control etc.), I'd say look into that but its sounds isolated.
Could be a bad recepticle as well, a bare wire could be in contact with it causing blown fuses.
Old 03-05-2010, 05:45 PM   #5
Blogger
99ford's Avatar
^ well put but I think maybe they are thinking the DC outlet ? To plug a gps or cell phone, etc..
Old 03-05-2010, 06:42 PM   #6
You can plug any DC 12 volt accessory into the cigarette outlet...just take out the cigarette lighter and it's basically the same as the one in the center console.
That seems to be the one that has trouble first.
Old 03-06-2010, 12:00 AM   #7
big show 98's Avatar
Check for any small particles or metallic trash that could have fallen into the slot.
big show 98 is offline   Reply With Quote
Old 03-06-2010, 07:42 PM   #8
Zebs5408's Avatar
mine doesnt work in my 04, i have always assumed a fuse!
04' mustang 3.9 40th Anniversary Edition- (V2 Vortech Supercharger, 38# injectors, 3.73 gears w/ T-lok, Predator Diablo, Mac cold air intake, Port & polished upper AND lower intake manifold, Mac Long Tube Headers, Mac o/r H pipe, flowmasters, 2.5 flowmaster tips)
03' Mustang GT (20" Cobra R's, 40 series Flowmasters)
Zebs5408 is offline   Reply With Quote
Old 03-06-2010, 09:20 PM   #9
Good chance it is the fuse. Do as w_nixon did and swap in a new fuse...then check the lighter to see if it blows the new fuse.
Old 03-10-2010, 02:28 PM   #10
OsirisGuy's Avatar
Make sure you are replacing it with the correct fuse. Just because there was a 5A fuse in there don't assume that it is 5A. Check the owner's manual and see what the required fuse should be.
If it is the correct fuse then I'd inspect the cigarette lighters/accessory outlets then. Make sure there isn't a coin stuck inside or any piece of metal which would complete the circuit and cause the short (fuse to blow).
Both the shifter outlet and the one in the center concole (in the arm rest) should be on the same fuse, so if that fuse goes then both outlets shouldn't function.
Also do you have any additional electronic accessories which are hardwired to the car? Even plugging multiple things into one socket will cause a big draw in current and blow the fuse.
OsirisGuy is correct
OsirisGuy is right
2002 Mustang GT
Old 03-10-2010, 03:31 PM   #11
upton7's Avatar
Always check and make sure there isn't a penny or dime or sumtin down there. When i replaced fuse after fuse after fuse I bought a cig lighter from auto zone or sumtin and It worked then I stopped using it cuz it gets ash everywhere. Just get a bic.
Old 03-17-2010, 07:02 AM   #12
SaleenFiend's Avatar
I had a dime stuck in mine for the longest time near the shifter and never knew. Once I finally saw the dime it must have taken an act of congress to get the dime out. My lighter has been inop since. I continue to use the outlet in the center console at this point.
Old 03-17-2010, 04:28 PM   #13
ain't that just a biatch! lol
Old 03-17-2010, 06:19 PM   #14
Blogger
99ford's Avatar
I would just buy the BIC (I'm partial to them, so don't listen to me.) if it's just the lighter that doesn't work. If the whole outlet doesn't work then try checking the wires.
Old 03-19-2010, 12:50 PM   #15
OsirisGuy's Avatar
Updates?
I like BIC too until I got my Ford Zippo. Also don't carry a white BIC, that's a no-no
OsirisGuy is right
2002 Mustang GT
Old 03-19-2010, 01:12 PM   #16
upton7's Avatar
Originally Posted by OsirisGuy View Post
Updates?
lol i know what you mean you supposed to stay about 10 feet away from someone using a red bic in this area. I was the same way when i got my jack daniels zippo but for some reason it just needs more lighter fluid like every day and I don't use it that much.
Old 03-19-2010, 01:15 PM   #17
Herbstang's Avatar
Hell Do what I did !! Quit smoking
Old 03-20-2010, 12:11 AM   #18
OsirisGuy's Avatar
Herbs, you quit smoking?!
OsirisGuy is right
2002 Mustang GT
Old 03-20-2010, 08:20 AM   #19
Ya, he quit "smoking", but not toking
change the fuse box cigarette lighter to turn off mexor The Bar 9 01-25-2004 03:10 PM
03:22 PM
