Will this fit? - Mustang Evolution
Old 09-19-2003, 09:05 PM   #1
NorwegianMustang's Avatar
Send a message via AIM to NorwegianMustang Send a message via MSN to NorwegianMustang Send a message via Yahoo to NorwegianMustang
Will this fit?
I just wonder if I can fit a '97 Cobra rear on my '95? The Cobras got IRS though :
NorwegianMustang is offline   Reply With Quote
Old 09-19-2003, 09:14 PM   #2
Black95GT's Avatar
Send a message via AIM to Black95GT
the cobra didnt get IRS until 99
-Jason
2003 DSG Cobra -2.2L KB, 60lbs Injectors, Single Blade TB, SCT2400 MAF, Kook's LT's, Kook's High-Flow Catted X-Pipe, Magnaflow CB, JLT RAI, MGW Short-Throw, H&R Race Springs, MM CC Plates, MM Bumpsteer, BF IRS Brace, BF Idlers, and AFS 18 Chrome Reps w/ R888s
Black95GT is offline   Reply With Quote
Old 09-19-2003, 09:18 PM   #3
So it will just bolt right on then, or do I got to modify something? Guess I got to change the drive shaft too, don't I?
Mods: Magnapacks, BBK X-pipe with cats, BBK CAI, hood struts, KYB Shocks/Struts, Eibach Pro springs, SS Inserts, CDC Light bar, Chrome 17" Bullits with Nitto 555 and N2O with dual purge
Old 09-19-2003, 09:21 PM   #4
Monkey's Avatar
ok, if its from a 97 cobra, it will be a direct bolt-on. if its from a 99+ cobra, it will not fit w/o about $1000 worth of other stuff
before 1999, the cobras had live axles like we do. since 1999, they have switched to the IRS. if it is the solid axle, then all you have to do is unbolt the lower control arms, upper control arms, shocks and driveshaft, then put the new rear end. you wont need to swap driveshafts, since fox bodies, they have been the same length.
Old 09-19-2003, 09:33 PM   #5
It's from a 97 cobra
Old 09-19-2003, 09:52 PM   #6
Monkey's Avatar
it will bolt right up to your car then. its a direct swap
Old 09-19-2003, 10:25 PM   #7
Well now you guys got me thinking, what if I wanted to put a (80's-90's) Cougar or t-bird IRS under a '88 mustang?
I know they exist, I have been told that it is a direct bolt in.. does anybody know for sure?
Also which center carrier do they have 8.8 or 7.5 or other?
-ron
<img src="http://phlegm.us/2coupes.jpg" align=right width="414" height="78">
My '68
My 67 upcoming project
SEth's '66
phlegm is offline   Reply With Quote
Old 09-20-2003, 11:15 AM   #8
Monkey's Avatar
they exist, but its not a direct swap. you need the conrtorl arms, the exhaust, the driveshaft, the shocks, the springs and some other things. IRS completly changes around the rear geometry and where everything goes.
im 99% sure theyre 8.8s.
Will it fit? Foxone General Mustang Discussion 3 12-05-2008 11:29 AM
will it fit? powerhungry966 1979-1995 Mustang GT 23 06-10-2006 11:01 AM
Would they fit? Js281GT Mustang Wheels & Tires 19 03-14-2005 05:02 PM
Will it fit? juice300x3 Mustang Audio & Video 1 08-26-2004 08:09 PM
would this fit the 02 v6 STEVE Pre-2005 V6 Mustang 26 07-19-2004 01:15 PM
» Members Mustangs
perkastang
mrjp64
G.L.
joe89
Add your Mustang
11:39 PM
